June 24, 200916 yr Author RE: 7.09 ohms (D4 in series)Fs: 28.4 HzQes: 0.511Qms: 5.75Qts: 0.469Vas: 40.3 LBL: 25.04 NALe: 7.7 mHMms: 252 gBL^2 / RE: 88600 watts RMSDepth = 6.5"Cut-Out = 10 15/16"Enclosure Suggestions:1.75 ft^3 ported tuned to 30 Hz -- F3 of 26 Hz* Tune higher and use a smaller box for more SPL oriented setup (Use 1 - 1.5 cubes)* Enclosure can be as big as 2.25 ft^3 with lower power levels1.00 ft^3 sealed -- F3 of 44 Hz* For SQ and space limited applications
June 24, 200916 yr Author 153.3 dB @ 47 Hz so farI'll clamp the power shortly... but I don't think it is really all that much all things considered. HU is at -10 on sub control -- as far down as it goes. I had it at -4 to put up the 154.1 with the single Nightshade 15"
June 24, 200916 yr Author Just clamped power... 4840 watts total power on my clamp. So about 1200 per sub on a burp to do that score -- this run was 153.4 dB as well, a tenth higher
June 25, 200916 yr Author two 3500D? or two 3000D?excellente!Two 3500D. I am not using the full power, of course, but I had two 3500s installed already
June 26, 200916 yr Just clamped power... 4840 watts total power on my clamp. So about 1200 per sub on a burp to do that score -- this run was 153.4 dB as well, a tenth higher what was the rise?
June 26, 200916 yr Author Just clamped power... 4840 watts total power on my clamp. So about 1200 per sub on a burp to do that score -- this run was 153.4 dB as well, a tenth higher what was the rise?Didn't measure rise. My clamp will give a power read out without breaking down voltage and current.
