Posted July 16, 200917 yr Just here to introduce myself.... Name is Danny... Just got back into car audio after a long break customizing PCs... Looking into getting a new subwoofer to replace an old setup I just re-installed in my 2003 Camry...System Build:Pioneer Premier 610BTKenwood amp 70x4 (interiors)KAC X810D (mono)2 JL AUDIO 10w3(6-7 years old)Q-Logic BandpassLooking to just have one 12" most likely..Any recommendations on a new sub for replacement?
July 16, 200917 yr If you are going to stick with the Excelon I would do a SSA ICON. If not, what is your budget?
July 16, 200917 yr Author If you are going to stick with the Excelon I would do a SSA ICON. If not, what is your budget?I will be sticking with the Excelon, it is so well built that I need no other one for the setup I'm going for. As far as the SSA ICON goes it looks pretty nice... Low wattage though it seems... I was looking at the Fi SSD 12" but not sure...M budget will be around $250 at most....
July 16, 200917 yr The Icon is 1000watts rms which is what you amp is rated for at 1 ohm. You would be very happy with it.
July 17, 200917 yr Author The Icon is 1000watts rms which is what you amp is rated for at 1 ohm. You would be very happy with it.As far as differences between the two subwoofers... There alot (spec wise)... What is the deciding factor on which would sound better? I def need something accurate, the sub setup now isn't much of accuracy wise....Is the icon better musically or the SSD by Fi?
