Over the years we have a had a lot of street rod and race car customer come to us looking for a product that could withstand the high temperatures on the engine side of the firewall. Some cars reach levels of 1000 degrees f. and for this application, we had no product to offer them.
Now we are about 8 weeks out from releasing our newest thermal insulation mat.
This new material is a multi layer composite that can withstand temperatures in excess of 1000 degrees when as little as 2 inches of air space is provided between the heat source and the product.
At ¼ inch thick and weighing in at .25 lbs per sq foot this is going to be our best thermal insulation material yet.
The foil is about 12 mils thick with a dimpled texture to increase surface area.
The Organic fibers are capable of withstanding temperatures over 1000 degrees, and the pressure sensitive adhesive is an acrylic hybrid that will grip on to any painted or primed metal surface, as well as plastic.
When subjected to a heat source of 1200 degrees the opposite side of the panel will get reduced to around 350 f.
When subjected to a heat source in the 300 degree range, the opposite side of the panel will get reduced to around 85 f. or so.
Not only can it be used on the engine side of the firewall, but it can also be used under the car, above the exhaust or transmission to block external heat as well.
Now, all we have to do is come up with a name for it.
That is where you come in. We are offering a $250 gift code to the first person that suggests the name that we decided to use.
We are posting this offer on several different forums and will be selecting a winner in the next month or so.
We have about 8 weeks before the product is ready to ship so we can take our time and wait for the right name to show up.
Thanks for your help!
ANT
www.secondskinaudio.com
  • Replies 82
  • Views 10.3k
Second Skin InsulPad
Second Skin InsulMat
Second Skinulate
Second Skin ThermaPad
Edited by tech2332
SecondSkin FireIce
Secondskin Dragwall
Secondskin IncinaFreeze
Secondskin Volcaniskin
Secondskin Engenius
Secondskin TherMight
Secondskin Thermal-Block
Secondskin CoolRod
Secondskin FarenheitReducer
Secondskin EngineCooler
Secondskin FirewallContainer
Secondskin IceAgeFoil
Secondskin EngineBlanket
Secondskin SunRayless
Secondskin GlobalCooling
Secondskin EverSeal
Secondskin InfiniCe
Secondskin MagniFire
Secondskin Hotpad
Secondskin Hotmat
Secondskin ArmorWall
Secondskin ArticMat
Secondskin PolarMat
Secondskin MagmaMat
Secondskin MoltenMat
Secondskin GlacierMat
Secondskin OzoneMat
Secondskin MercuryMat
Secondskin Death Valley Series
Secondskin Thermodynamic Barrier
Secondskin CrystalMat
Secondskin CryogenMat (Cryogenics - the branch of physics concerned with the phenomena at low temps.)
Secondskin Cryotherapy (Cryotherapy - medical treatment using extreme cold)
Secondskin EquatorShield
Secondskin AntarticaRacing
Secondskin HeatSinkPad
Secondskin CoolRunnings
This is turning out to be quite a play on words!!LOL
Thesaurus to the rescue!!!! LMAO
Secondskin OmniBlock
Secondskin Two Fifty -lol
Secondskin Immortal
Secondskin Deadzone
Secondskin Solidifite
Secondskin Kelvinite
Secondskin ThermaCoolMat or ThermaCool
Secondskin TuffMat (or Tough)
Secondskin IntenseMat
Secondskin ResilientMat or ResiMat
Secondskin IcyMat
Secondskin Chill or ChillMat
Secondskin FrostyMat
Secondskin ApexMat
Secondskin MaxMat or MaximumMat
Secondskin CrownMat
SecondSkin Heat Mat
SecondSkin 1000
SecondSkin CoolTouch
Secondskin FirewallRefrigerant
Secondskin SolarShield or FahrenheitShield
Secondskin CooldownMat
hey, u took my Armorwall! I already posted that on the first page.
I'm tellin the Deadener Police on you!
