Posted July 22, 200917 yr Over the years we have a had a lot of street rod and race car customer come to us looking for a product that could withstand the high temperatures on the engine side of the firewall. Some cars reach levels of 1000 degrees f. and for this application, we had no product to offer them.Now we are about 8 weeks out from releasing our newest thermal insulation mat.This new material is a multi layer composite that can withstand temperatures in excess of 1000 degrees when as little as 2 inches of air space is provided between the heat source and the product.At ¼ inch thick and weighing in at .25 lbs per sq foot this is going to be our best thermal insulation material yet.The foil is about 12 mils thick with a dimpled texture to increase surface area.The Organic fibers are capable of withstanding temperatures over 1000 degrees, and the pressure sensitive adhesive is an acrylic hybrid that will grip on to any painted or primed metal surface, as well as plastic.When subjected to a heat source of 1200 degrees the opposite side of the panel will get reduced to around 350 f.When subjected to a heat source in the 300 degree range, the opposite side of the panel will get reduced to around 85 f. or so.Not only can it be used on the engine side of the firewall, but it can also be used under the car, above the exhaust or transmission to block external heat as well.Now, all we have to do is come up with a name for it.That is where you come in. We are offering a $250 gift code to the first person that suggests the name that we decided to use.We are posting this offer on several different forums and will be selecting a winner in the next month or so.We have about 8 weeks before the product is ready to ship so we can take our time and wait for the right name to show up.Thanks for your help!ANTwww.secondskinaudio.com
July 22, 200917 yr Second Skin InsulPadSecond Skin InsulMatSecond SkinulateSecond Skin ThermaPad Edited July 22, 200917 yr by tech2332
July 22, 200917 yr Secondskin DragwallSecondskin IncinaFreezeSecondskin VolcaniskinSecondskin EngeniusSecondskin TherMightSecondskin Thermal-Block
July 22, 200917 yr Secondskin CoolRodSecondskin FarenheitReducerSecondskin EngineCoolerSecondskin FirewallContainerSecondskin IceAgeFoilSecondskin EngineBlanketSecondskin SunRaylessSecondskin GlobalCooling
July 23, 200917 yr Secondskin GlacierMatSecondskin OzoneMatSecondskin MercuryMatSecondskin Death Valley SeriesSecondskin Thermodynamic Barrier
July 23, 200917 yr Secondskin CrystalMatSecondskin CryogenMat (Cryogenics - the branch of physics concerned with the phenomena at low temps.)Secondskin Cryotherapy (Cryotherapy - medical treatment using extreme cold)
July 23, 200917 yr Secondskin EquatorShieldSecondskin AntarticaRacingSecondskin HeatSinkPadSecondskin CoolRunnings
July 23, 200917 yr This is turning out to be quite a play on words!!LOLThesaurus to the rescue!!!! LMAO
July 23, 200917 yr Secondskin OmniBlockSecondskin Two Fifty -lolSecondskin ImmortalSecondskin DeadzoneSecondskin SolidifiteSecondskin Kelvinite
July 23, 200917 yr Secondskin ThermaCoolMat or ThermaCoolSecondskin TuffMat (or Tough)Secondskin IntenseMatSecondskin ResilientMat or ResiMatSecondskin IcyMatSecondskin IntenseMatSecondskin Chill or ChillMatSecondskin FrostyMatSecondskin ApexMatSecondskin MaxMat or MaximumMatSecondskin CrownMat
July 26, 200917 yr Secondskin ArmorWallSecondskin FirewallRefrigerantSecondskin SolarShield or FahrenheitShieldSecondskin CooldownMat
July 26, 200917 yr hey, u took my Armorwall! I already posted that on the first page.I'm tellin the Deadener Police on you!
