Posted July 25, 200917 yr What would the best electrical setup for a 2000d?I got a 1800 upfront and a 1400 in the back. Big 3 done with 0awg, 0awg to the amp and a stock 90 amp alternator. Would I be able to use the amp at its full potential? Any recommendations?
July 25, 200917 yr i would say a bigger alt to use the full power of a 2000d. maybe around 120-150! but other then that you already have enough battery power! o and don't forget to get a volt meter!!
July 25, 200917 yr Author i would say a bigger alt to use the full power of a 2000d. maybe around 120-150! but other then that you already have enough battery power! o and don't forget to get a volt meter!!I was planning on rewinding the alternator, than possibly upgrading the alt to a bigger one if it doesn't help hold the voltage, anyone tested to see what the amp does at .5 ohms or .3 ohms ?
July 25, 200917 yr i would say a bigger alt to use the full power of a 2000d. maybe around 120-150! but other then that you already have enough battery power! o and don't forget to get a volt meter!!I was planning on rewinding the alternator, than possibly upgrading the alt to a bigger one if it doesn't help hold the voltage, anyone tested to see what the amp does at .5 ohms or .3 ohms ?naw I dont think anyone wants to void their warranty just yet for the SAZ-2000d but Im pretty sure Jacob or someone from Sundown may do a test at that ohm load to give you some results.
