Posted July 29, 200916 yr I've got an xcon 15d2 run by a sundown saz1500d they have been hooked up for about a month and both are great. I was driving a few days ago and everything was fine i parked my truck and went to move it a few hours later and it wasn't playing rite. It plays quiet and when you put your ear to it, it makes a buzzing noise. i pulled the sub out and it does not smell burnt and both coils read about 1.8-9 ohms on the DMM. Sorry for the long post but i have no idea what is wrong. Any help would be great.
July 30, 200916 yr Admin Is there anything loose with the enclosure or on the driver it self? Did you also check all your wiring?
August 4, 200916 yr Author I found out that the problem was a bad rca NOT the sub. It has been flawless since.
August 4, 200916 yr Admin I found out that the problem was a bad rca NOT the sub. It has been flawless since.Thats good to hear. Glad you got it worked out.
