Posted August 1, 200917 yr http://www.cdstandbypower.com/product/battery/vrla/pdf/12_1029.pdfit is the 100 lb battery idk which one it is ik there is 2 of them ... how are they ... someone is selling them for around 250 each on a car audio forum ... they are supposed to be comprable to the kinetic hc3800 he said Edited August 1, 200917 yr by Lucky 76
August 1, 200917 yr i have seen those batteries before and heard they off some of the best battery power around! the only negative is the 100lb!! other then that ppl say you can't get much better!!
August 1, 200917 yr Author i have seen those batteries before and heard they off some of the best battery power around! the only negative is the 100lb!! other then that ppl say you can't get much better!!the model number is UPS12-475fr .... would you say they are better than the powermaster d3100?
August 1, 200917 yr Author i have seen those batteries before and heard they off some of the best battery power around! the only negative is the 100lb!! other then that ppl say you can't get much better!!the model number is UPS12-475fr (replaced by the UPS12-490MR).... would you say they are better than the powermaster d3100?
August 1, 200917 yr RidinClean is using them in his Expedition build. Go check out the building Log section. If he doesnt chime in you might want to sent him a message. Im sure he'll give you his opinion of them
August 3, 200917 yr Have you found anymore info about this batt? How to order, how much? I wouldn't mind to maybe try a couple out. Pm me if anymore info. Thanks
August 3, 200917 yr Author Have you found anymore info about this batt? How to order, how much? I wouldn't mind to maybe try a couple out. Pm me if anymore info. Thanksno1 is responding to this post so idk if n e 1 has n e more info either ... if u look at the link it seems to be a good battery ... i just dont know if i should get these or the powermaster d3100s
August 3, 200917 yr $250 each? That seems like a little much. I've seen these go for like $150. If I remember correctly, I saw them go for $110 plus shipping on CA.com.Unfortunately I don't know much about the battery itself. Sorry. Edited August 3, 200917 yr by inkfx
August 3, 200917 yr Author $250 each? That seems like a little much. I've seen these go for like $150. If I remember correctly, I saw them go for $110 plus shipping on CA.com.Unfortunately I don't know much about the battery itself. Sorry.i cant find them anywhere that cheap ... do you think you can send me a link i cant find them on that website?
August 3, 200917 yr Here is the guy selling them for $110 + shiphttp://www.caraudio.com/forum/showthread.php?t=419772&highlight=%24110
August 3, 200917 yr Author Here is the guy selling them for $110 + shiphttp://www.caraudio.com/forum/showthread.php?t=419772&highlight=%24110thanks ... how many of these should suffice for the new saz4500 and 2 of the sax125.2 ... i have a 260 amp alt already Edited August 3, 200917 yr by Lucky 76
