i wonder if the SAZ-1000D would be a good amp for midbass
at the moment i'm running a 100.4 for mids/highs and the 125.2 for the midbass
now i wanna get 8 (4 in each door) SPL Dynamics HF6.1 for midbass, but i don't think the 125.2 will have enough power for 4 per channel so i thought about going with 2 SAZ-1000D
anyone tried them for mids yet?
If you only want to play up to a maximum of 300 Hz it will be fine.
over 300 it would be a problem?
i wanted to cut them at 800hz with 18db
The amp will not play over 300 -- the LPF is non-defeatable and maximum setting is 300 Hz.
meh =/
what about the older SAE amps ?
i may would get a 2nd 125.2, but the HF6.1 are 3ohm, so it would see 1.5 per channel and i don't know if the 125.2 will be stable at that load =/
btw. i wouldn't mind seeing a big 2 channel Sundown amp
like 500.2 , 500x2 @ 4ohm and 1ohm stereo stable, that would be awesome
Edited by Biggy
VERY little demand for a high current Class A/B amp, IMO.
None of the Class-D amps LPF goes above 300 Hz.
than i have a problem
You have four 3 ohm speakers per door ?
Bridge a 100.4 per side at 3 ohms... what is the DCR ?
~300watt for 4 mids with a 3" coil?
i think i would need a bit more =/
Find an older ARC Audio XXK or CXL series amp.
270 x 2 @ 4 ohms, 525 x 2 @ 2 ohms
i still have some old orion and ppi amps sitting arround, but i wanna stay all sundown amps in my car
Edited by Biggy
