I'd like to pick up a 15" icon. The box would be sealed, but to shallow to mount the sub. I have the room to do inverted. Is that an option? Will it have a negative affect on the subs performance?
when inverting a sub you may hear the motor structure slightly....
sort of a twanging noise but it will go away a bit with break in
the inverted sub does loose a bit of SQ to
  • Admin
You can invert it no problem, just reverse the speaker wires. :)
Thanks for the replies. I didn't realize I had any. I'l have to set up my alerts.
