Posted August 10, 200917 yr First, should i get the 2ohm build and wire it down to 1ohm? Or get the 1ohm build? Also,I will be getting a sundown amp, but which one? I think the 1500 will serve it's purpose, won't it?
August 10, 200917 yr a sundown amp would work best if you get a dual 2 ohm sub.What amp?SAZ-2000D is what i would recommend for the average user.If you are crazy with running equipment and can safely setup amps and monitor subs status during playback, i'd put the SAZ-4500D on it but that's just me... i like overkilled-headroom.
August 10, 200917 yr Author a sundown amp would work best if you get a dual 2 ohm sub.What amp?SAZ-2000D is what i would recommend for the average user.If you are crazy with running equipment and can safely setup amps and monitor subs status during playback, i'd put the SAZ-4500D on it but that's just me... i like overkilled-headroom.Haha no theres no way I can get my electrical system to handle a 4500, let alone have the room in a 3 series beemer.
