Posted August 10, 200917 yr i dont have that much trunk space, around 12 cft. is a box of 11 cft including port displacement enough for two btls?
August 10, 200917 yr If that is after displacements... JUST about doable. I would run no less than 13 cubes in an Ideal world.
August 10, 200917 yr I think your port and sub displacement is going to exceed 1 cube by quite a bit. Just get two 15s, they'll be much happier.
August 10, 200917 yr Author minimal recommend box volume is 10 cft. how do the btls sound if its a small enclosure?
August 10, 200917 yr You have 10 cubes after diplacements? I'd look at 15s personally. Smaller you go the less efficient near tuning they will be. And it already seems you don't have a prayer when it comes to the power supply you currently have planned!
August 11, 200917 yr Author oh damn i had my car measured wrong... i have 16 cft space, should be enough now.
