August 11, 200916 yr Admin That is going to be hard to say since the SA-12 is fairly new to market. They should certainly be up there with the IA LI in performance respective to the power ratting. But until someone has put them both in the same install, it is not that easy to say. Jacob has done some high output testing.
August 11, 200916 yr That is going to be hard to say since the SA-12 is fairly new to market. They should certainly be up there with the IA LI in performance respective to the power ratting. But until someone has put them both in the same install, it is not that easy to say. Jacob has done some high output testing.Mine are on the way! I will let you know how they sound.
