SA-12 cone, spider, dust cap, coil + 4-spoke frame w/ 6.25 mm spacers
Atomic Apocalypse 2.5" Coil Motor
Going to measure T/S specs tomorrow
RE: 7.5 ohms
FS: 31.28 Hz
Qes: 0.546
Qms: 5.627
Qts: 0.498
Le: 7.03 mH
Vas: 29 L
BL: 26.6 N/A
Cms: 99 uM/N
Mms: 260 g
Motor strength is right on par with the actual SA-12 within a few %
It is still fresh, Fs should drop to 28 Hz or so with more play time :)
The Cms is currently 99 uM/N and will settle closer to 140 uM/N (about 40% looser)
RE: 7.5 ohms
FS: 31.28 Hz
Qes: 0.546
Qms: 5.627
Qts: 0.498
Le: 7.03 mH
Vas: 29 L
BL: 26.6 N/A
Cms: 99 uM/N
Mms: 260 g
Whatever that means, it should be sick :lol:
