Im trying to see which sub is a good "SQL" sub. I had a 10w7 in a ported box and it rocked. Im looking to put 2 10's in my nissan titan in a ported box, its gonna have about 1.3 cu ft for each chamber, powered by a sundown 2000d.
Im trying to see which sub is a good """SQL""" sub. I had a 10w7 in a ported box and it rocked. Im looking to put 2 10's in my nissan titan in a ported box, its gonna have about 1.3 cu ft for each chamber, powered by a sundown 2000d.
the Q is fi's SQ line.
budget
Sealed will definitely get u better sound quality than ported .......
ok sorry for the newb question. Im looking for a blend of sq and spl. I want to to rumble but at the same time sound clean. I have about 500 bucks to spend on subs.
Sounding clean has NOTHING to do with the term SQ. If you want any SQ you loose all rumble. Read the noob posting guidelines (in my sig)
Ok then the fi q isnt for me then.
I think you're right bout the bl's.
Edited by gfronty
or you can try a pair of Icons, they sound excellent.
No it won't.
