hey all, i was just wondering, how much of an improvement in spl and sq (in your opinion) if any will i get switching my LI in for an RL-P i just ordered??
All with the same amt of power about 550-600w, and same box (but shrinking the internal volume by .75 cubic feet.) and tuning it around 30-32 hz.
you could tune to 28hz, that would be what mike reccomends
kay i talked to mike and he told me to tune it to 31-32 hz but okay!
then disregard my post, Mike is teh last word on these subs, so listen to him, I was just mentioning 28 because that is what I built to from past info
:fing34:
Just to clear up any potential confusion (this one's for you denim! kickass.gif:D ) .. I generally tend to advocate a slightly higher tuning for the 12's (30-34 Hz) as opposed to the 15's (28-32 Hz) - and, if I know a bit more about the environment the woofer is going into, that may play a role in what I may ultimately recommend.
.. and then there's the whole matter of personal taste :ohsnap::Doh: :ph34r:
Just to clear up any potential confusion (this one's for you denim! kickass.gif  :D  ) .. I generally tend to advocate a slightly higher tuning for the 12's (30-34 Hz) as opposed to the 15's (28-32 Hz) - and, if I know a bit more about the environment the woofer is going into, that may play a role in what I may ultimately recommend.
its goin in the trunk of my 84 benz. And there is a gas tank that is in between the cabin and the trunk.
