Posted September 12, 200917 yr Ok if I build a box that has a port that 'folds' would that be just as good as a regualr port?
September 12, 200917 yr Author Ok if I build a box that has a port that 'folds' would that be just as good as a regualr port?Yes its very crudely drawn but I just wanna know. Also is there a name or terminology for that type of port?
September 12, 200917 yr Author T-Line (Transmission)so if I was looking to tune the box to a certian Hz and I made a port like that instead of a straight out port it would sound the same?
September 12, 200917 yr If your using a standard port design and you break it down to look like that vs a standard L-shaped port should not really have any audible difference. A T-Line enclosure is a whole different design. ..... Read the link belowhttp://www.quarter-wave.com/
September 12, 200917 yr Author Whoa, so I should probably stick to an L-shape port then is what your telling me. Also are Hifonics amps any good? just a random question.
September 12, 200917 yr Whoa, so I should probably stick to an L-shape port then is what your telling me. Also are Hifonics amps any good? just a random question.For a beginner yes stick with a standard L-Shaped slot port. Hifonics? Personally I would buy Sundown.
