Posted September 15, 200916 yr Scott suggested that I do a 0.47 cu ft box. I'm having trouble finding the right dimensions. Can anyone help?
September 16, 200916 yr Width = 12"Height = 13.5"Depth = 8"Puts you right at .47 cu ft. That is if youre using 3/4" MDF.
September 16, 200916 yr Author Width = 12"Height = 13.5"Depth = 8"Puts you right at .47 cu ft. That is if youre using 3/4" MDF.Thanks, that looks like a good fit for my car.
September 16, 200916 yr You should account for sub displacement too. After sub displacement (.12ft^3) your at .35ft^3, if you increase the depth to 9.5" that will put you at .46ft^3 or 9.75" at .48ft^3 after sub displacement.
September 16, 200916 yr Author 0.35 after displacement is the goal according to the FI techs. Just now have to order the SSD before they stop building them.
September 16, 200916 yr Just now have to order the SSD before they stop building them.Where does it say they are going to stop building the SSD line?
September 16, 200916 yr Scott suggested that I do a 0.47 cu ft box. I'm having trouble finding the right dimensions. Can anyone help?http://www.the12volt.com/caraudio/boxcalcs.asp#rec
