Posted September 17, 200915 yr I'm building up a "foundation" for a future bass race setup in my Jeep. Right now, it's just for two 15's but I would like to get some heavy duty 18's in the future once I add more power to the mix.... The rear chamber is 9 cubes tuned to 33 hz and the front chamber is big with a big port The port and subs from the rear chamber will be facing right in front of the loading wall. For anybody that asks why I used particle board....Lowe's was out of MDF, plus it was cheaper. Not a big deal to be honest. We'll start off with what was in my Jeep before:Start of the tear out...
September 17, 200915 yr Author Rear chamber build up:2nd layer of the floor:Big bucket of number 3 screws:Some helpLoading wall
September 18, 200915 yr Author haha, there's glue. I've gone through about 3 tubes of PL adhesive and 4 tubes of liquid nails.
September 18, 200915 yr Author Not much done today so I didn't take any pictures. I filled in some screw holes and smoothed some stuff out with body filler. I might have to pick up some more wood tomorrow morning.
September 18, 200915 yr Looks heavy - are the headlights pointed at the sky yet?Should be very impressive once it all goes together.
September 22, 200915 yr Author Okay, I can't find my camera but I got the baffle for the rear chamber on and most of the front chamber has a nice layer of resin and the wheel arches have been fiberglassed over. So far everything is nice and strong.
September 23, 200915 yr Author Found my camera. I couldn't get a good angle for the rear chamber on some of the pics.
September 28, 200915 yr Author It's finished for now but my XA3000D blew and I have no idea why. I wanted to start testing and fine tuning it this week but I guess not If anybody wants to give me an amp that would be great!
October 29, 200915 yr See if you can find some way/method to round over that partition - like using a large piece of doweling cut in half for example. Maybe snag a 6" sonotube and cut that in half.Also look at the inside corners - see if you can find an easy way to round those as well. Maybe look into the small sonotube or even a mailing tube you can glue to the corners and add a bit of bondo to smooth out the edges.In for a penny, in for a pound!
October 29, 200915 yr Author Yeah, I still have a lot of stuff to do with it, if only I could find the time.
October 29, 200915 yr See if you can find some way/method to round over that partition - like using a large piece of doweling cut in half for example. Maybe snag a 6" sonotube and cut that in half.Also look at the inside corners - see if you can find an easy way to round those as well. Maybe look into the small sonotube or even a mailing tube you can glue to the corners and add a bit of bondo to smooth out the edges.In for a penny, in for a pound! Actually, I would test it the way it is first, THEN start rounding corners over (one at a time).No sense in wasting time and money if it doesn't help anything.
