Posted September 17, 200917 yr Hi there,its bin a looong time since my last project so i wanted something new. got a new car and redid everything.setup so far..2 RF t20001bds15 inch BTL fully loadedHertz EP 2X Amp for SystemsRadical Audio Reference 16.2 SystemsZenec LCD Headunit2 Kinetik 1400sHO AltBig 3All 1/0 GaugeAudiocontrol OverdriveFirst thing was to pop the original 4 Cylinder 45hp Engine out and put the 6 Cylinder VR6 Engine in. I dont have pics of the engine change just a pic from the engien room.. well here are pictures ive made, more to come tomorrow..
September 18, 200917 yr I'd like to point out the fact that those RF amps put out more power on 2 ohms than on 1 ohm and those amps dont like to be strapped , they run hot quickly when you do .besides that its looking good !
September 18, 200917 yr Author i know i dont use the bd sync i just link them with rcas and they put out the same power, so one amp per coil, worked pretty good for almost a year...And the BTL is dual 2 Ohms so i use each amp at 2 omhs thanks for your comments hope the get the rest in today. but i have to use my oldest enclosure first before the new is finished
September 18, 200917 yr will work fine on music but for burping only you'll probably will want to change the impedance on those coils .what kind of box do you have in mind ?
September 18, 200917 yr Author i know i should recone to dual 1, i have to contact bladeice for that..im not shure yet but about 3.8 cuft at 53hz for burping but im not shure yet...it will take a few boxes to find the right one Edited September 18, 200917 yr by faezich
September 22, 200916 yr Author Hi there,well evereythings in and its awesome!!!Brutal Bass like This is the current box you see but im not sure yet how to build the new because theres almost no space for a nice one, but ill find a solution.I had to use a relais for remote because the HU was not able to power all amps up, look at the wiring mess because of the HU I dont have my drivers licenense at that time (damn p...ce) so it will take another 2 weeks till i get it metered... But here are the pics ive made
