Posted September 25, 200917 yr i have a MA Audio hk15x2 and i was wondering if i am able to invert it.and if i do that i have to invert the polarity right?
September 25, 200917 yr i have a MA Audio hk15x2 and i was wondering if i am able to invert it.and if i do that i have to invert the polarity right?Pretty much any sub can be inverted.
September 25, 200917 yr Author alright thanksso i just have to switch the pos and neg after i remount it? Edited September 25, 200917 yr by Bri Bri
September 25, 200917 yr alright thanksso i just have to switch the pos and neg after i remount it?If it's only one sub, then no, it doesn't matter. If there are two subs, and only one is inverted, then yes, you will need to switch the polarities.If there are more than one with one inverted and one not, and the polarities aren't switched, you will get cancellation...Basically when the subs are on they're up stroke, one will excurt out of the box, and the other will into the box. Edited September 25, 200917 yr by rmzsuzuki89
September 25, 200917 yr alright what does it actuall doIt changes the polarity of the driver, or in simple terms, changes the way the cone moves .
September 25, 200917 yr Author alright what does it actuall doIt changes the polarity of the driver, or in simple terms, changes the way the cone moves .will it make it sound different with only one sud
