Posted September 25, 200915 yr Are they really backed up right now, If I order today when should I get my subs? I'm looking to get 2-12" Q's , just wondering if it takes a long time to get the subs. And Would 2 RF 1500-1's be good on these subs for a daily driver. Want subs to sound good on a variety of music (rock, rap, some country,metal ). Would get the 2 ohm version so I could strap amps together at 2 ohms. Edited September 25, 200915 yr by rak_24540
September 25, 200915 yr Are they really backed up right now, If I order today when should I get my subs? I'm looking to get 2-12" SQ's , just wondering if it takes a long time to get the subs. And Would 2 RF 1500-1's be good on these subs for a daily driver. Want subs to sound good on a variety of music (rock, rap, some country,metal ). Would get the 2 ohm version so I could strap amps together at 2 ohms.I'm assuming you are talking about fi? If so they are Q's, not SQ's. probably a little too much amp for a Q. Yes they are very busy as usual.
September 25, 200915 yr Lead time is still the typical 3-7 business days...as everything is built per order.I probably wouldn't run that much power to the Q's if that is what you are referring to.
September 25, 200915 yr I ordered on tues the 22nd....quantum view from ups says sub will be here tue the 29th... this was for a 15 q with bp option.So I'm assuming they're are flying pretty quick.Sad my amp won't show up till the day after lol.
September 25, 200915 yr Are they really backed up right now, If I order today when should I get my subs? I'm looking to get 2-12" Q's , just wondering if it takes a long time to get the subs. And Would 2 RF 1500-1's be good on these subs for a daily driver. Want subs to sound good on a variety of music (rock, rap, some country,metal ). Would get the 2 ohm version so I could strap amps together at 2 ohms.The lead time will alwasy be the same, you will get your subs within a 2-week time period from the day you order at the most. One of the Rockford Fosgate 1500-1 will be good enough or any 2000Rms am will do. If you want to use that much power on those subs I dont think you will need Q's, you might be more of a BL man since output is your concern.
September 25, 200915 yr I ordered on tues the 22nd....quantum view from ups says sub will be here tue the 29th... this was for a 15 q with bp option.So I'm assuming they're are flying pretty quick.Sad my amp won't show up till the day after lol.If it still says "Billing Information Received" they have not went anywhere..do not rely on when UPS says they will be there unless it says "In Transit"
September 25, 200915 yr I'm in my phone so I can't check it but I'm 95 percent sure it says in transit. If so it was very fast.
September 25, 200915 yr Are they really backed up right now, If I order today when should I get my subs? I'm looking to get 2-12" Q's , just wondering if it takes a long time to get the subs. And Would 2 RF 1500-1's be good on these subs for a daily driver. Want subs to sound good on a variety of music (rock, rap, some country,metal ). Would get the 2 ohm version so I could strap amps together at 2 ohms.The lead time will alwasy be the same, you will get your subs within a 2-week time period from the day you order at the most. One of the Rockford Fosgate 1500-1 will be good enough or any 2000Rms am will do. If you want to use that much power on those subs I dont think you will need Q's, you might be more of a BL man since output is your concern.1 of those amps is enough but make sure u change your sub's vc to match.
September 26, 200915 yr Author I will , if I only need 1, I will get dual one subs and run 1ohm. Is the SQ that much better on the Q's vs. BL's. No one around my area carries anything like these, so I've never heard neither one. The 2 shops here only carry Rockford, JL, Pioneer, Kicker, sony stuff, no FI , RE,nothing like that so I'm just going on forums Info to make a decision .
September 26, 200915 yr You aren't a Q buyer. BL perhaps, definitely not Q. Doesn't quite fit with cutting your backseat in half....nor does your question about lead time. Have you already built your box? I pretty much guarantee Fi will not be holding up your install...
September 26, 200915 yr Author No I have not built the box yet. I'm trying to decide on which subs to get first. I'm re-doing my wiring now, if it ever stops raining here. Putting 14 ga speaker wire to replace the 18 ga the shop around here put in the last time. I'm putting 8 ga wire to my subs. I'm replacing the Infinity kappa's in the kick panel's with MB Quart PVF's, (german made) I'm going to get the MB PCE 164 mid bass to put in my doors. My sub set up now is 2-RF T110's in a sealed box under back seat fiberglassed to the floor. So that going to be something to get out in the first place. I thought this set up would be good for rock or metal for tight punchy bass, but it sounds better with rap than rock. I listen to a variety of things and want it to produce good sound and output to whatever I listen too.
September 26, 200915 yr Sounds like your a BL listener! Stay within Fi's recommended box specs and you should be loud and still maintain good sound.A little reading below to help in your decision...
