Posted October 11, 200915 yr Im tryna purchase 2 Fi BL 15's and i have a power acoustik BAMF40001/D...Im wondering how I should wire the voice coils and would it be better to get a dual1 or dual2???...This is for daily use also
October 11, 200915 yr Im tryna purchase 2 Fi BL 15's and i have a power acoustik BAMF40001/D...Im wondering how I should wire the voice coils and would it be better to get a dual1 or dual2???...This is for daily use alsoGet Dual 1 ohm subwoofers, wire each of them in series to 2 ohms and they will drop down to 1 ohms at amp since the amp is 1 ohm stable.
October 11, 200915 yr Author preciate it..but how can u power a negative and a positive..i thought that would put the amp in protectiion
October 11, 200915 yr Naw what puts an amp into protection is usually wrong ohm load wiring and some other things but not that.
October 11, 200915 yr Author aw aight....1 mo question..wiring in series give you 1 positive and 1 negative wire to go into the amp right...would you just not use the other 2 speaker inputs on the amp and leave them open??
October 11, 200915 yr aw aight....1 mo question..wiring in series give you 1 positive and 1 negative wire to go into the amp right...would you just not use the other 2 speaker inputs on the amp and leave them open??Its two ways to do it:Option #1:You wire each sub individually, one to each set of the amps terminals and let the amp drop the 1 ohm load (no speaker terminals will be left unused).Option #2:You wire each sub individually then together before it reaches the amp to drop to 1 ohm load, to one set of speaker terminals (one set of speaker terminals will be left unused).
October 11, 200915 yr No problem man, good luck on the install and dont forget to spoil us with a build log or pictures.
