Posted October 16, 200916 yr Hi all.I am looking to replace the stock sub in my Lexus GS 430 w/ Mark Levinson system. (to start)I will be replacing the front door speakers and dash tweeters with components later (probably Focal 6.5 K2s),The rear deck fill speakers will remain stock (if they sound OK after the upgrades elsewhere)Fist I would like to start with the subwoofer. I have a JBL 300W mono amp to power the sub I will be adding.Will the SD10 work as in IB sub?The stock sub I am looking to replace is a 10" mounted in the center of the rear deck.The sub will fire up towards the rear window creating a horn effect like the stock sub.The Q looks close and the Fs in nice and low- will this sub work or can you reccomend one that will? (a 12 will not fit w/o hacking up the deck opening)Thanks!
October 16, 200916 yr Admin Welcome to SSA. I believe Fi might be able to customize a Q or SSD to be more IB friendly, if not the standard versions are still very good choices.
October 16, 200916 yr Welcome .... Email Fi and ask if they could build a 10" IB series subwoofer for you.
October 16, 200916 yr Author Welcome .... Email Fi and ask if they could build a 10" IB series subwoofer for you.Thanks Guys!
