Posted October 22, 200915 yr How much do you guys think i should sell my bl 18 for it is spl version d2?
October 22, 200915 yr More info would help: how long have you had it, how much power has it seen, how long have you used it and etc.
October 22, 200915 yr Author i got it a while back about a year ago, it is being powered by a kicker 1200.1 ran at 2 ohms, i have used it in competitions but never on burp.
October 22, 200915 yr i got it a while back about a year ago, it is being powered by a kicker 1200.1 ran at 2 ohms, i have used it in competitions but never on burp.There is no way you can run a D2 ohm subwoofer at 2 ohms.
October 22, 200915 yr Author i got it a while back about a year ago, it is being powered by a kicker 1200.1 ran at 2 ohms, i have used it in competitions but never on burp.There is no way you can run a D2 ohm subwoofer at 2 ohms.i mean 1 ohm sry
October 25, 200915 yr i got it a while back about a year ago, it is being powered by a kicker 1200.1 ran at 2 ohms, i have used it in competitions but never on burp.There is no way you can run a D2 ohm subwoofer at 2 ohms.Couldnt you just wire each vc to seperate channels at 2 ohm?
October 25, 200915 yr i got it a while back about a year ago, it is being powered by a kicker 1200.1 ran at 2 ohms, i have used it in competitions but never on burp.There is no way you can run a D2 ohm subwoofer at 2 ohms.Couldnt you just wire each vc to seperate channels at 2 ohm?He's talking specifically about the kicker amp he has, which is a mono amp.
October 25, 200915 yr i got it a while back about a year ago, it is being powered by a kicker 1200.1 ran at 2 ohms, i have used it in competitions but never on burp.There is no way you can run a D2 ohm subwoofer at 2 ohms.Couldnt you just wire each vc to seperate channels at 2 ohm?He's talking specifically about the kicker amp he has, which is a mono amp.'I knew I wasnt crazy! That sounded weird but I should have known better.
October 26, 200915 yr Author hey bigrank916 likin the truck looks like mine did... now its primer black
October 26, 200915 yr hey bigrank916 likin the truck looks like mine did... now its primer blackThanks. It still needs work though. Its the first ride I ever bought. Held on to it and been dumpin money in her ever since! I wanted to black mine out but dont now if Im gonna keep it.
