Posted October 25, 200917 yr Looking for thoughts on specs. I don't know a lot about T/S parameters and all, so looking for some insight. Leaving out brand and model for unbiased opinions. Thanks for any input.1800 watts power handling• 800 Watts RMS• 200 oz. magnet• 2” BASV voice coil• SPL 91 dB• Fs: 36 Hz• Vas: 1.91 cu.ft.• Qms: 5.71 • Qes: 0.502 • Qts: 0.462• Xmax: 0.4"• Sealed box: 1.2 cu. Ft.• Ported box: 2 cu.. Ft.• Tuning: 40Hz• Port Size: 4”(dia)x8.75”(length)• # of ports:1• Mounting Depth: 6.25”
October 25, 200917 yr Author Is it the driver listed in your sig?LOL, no it's not the driver listed in my sig, but another that I am considering.
October 25, 200917 yr for car audio use, i don't think it has enough fo an xmax rating for such power if tuned low...And speaking of power, how is that sub gonna handle it's 800wrms rating on a 2" VC?
October 25, 200917 yr Looking for thoughts on specs. I don't know a lot about T/S parameters and all, so looking for some insight. Leaving out brand and model for unbiased opinions. Thanks for any input.1800 watts power handling• 800 Watts RMS• 200 oz. magnet• 2” BASV voice coil• SPL 91 dB• Fs: 36 Hz• Vas: 1.91 cu.ft.• Qms: 5.71 • Qes: 0.502 • Qts: 0.462• Xmax: 0.4"• Sealed box: 1.2 cu. Ft.• Ported box: 2 cu.. Ft.• Tuning: 40Hz• Port Size: 4”(dia)x8.75”(length)• # of ports:1• Mounting Depth: 6.25”You have been all over the place with equipment from here and there, lets take a step back before you just keep throwing more and more equipment at us. What are your goals, your budget on amp, speakers, front stage, electrical upgrades, etc? I wouldnt get a sub with those T/S Parameters.
October 25, 200917 yr Author Looking for thoughts on specs. I don't know a lot about T/S parameters and all, so looking for some insight. Leaving out brand and model for unbiased opinions. Thanks for any input.1800 watts power handling• 800 Watts RMS• 200 oz. magnet• 2” BASV voice coil• SPL 91 dB• Fs: 36 Hz• Vas: 1.91 cu.ft.• Qms: 5.71 • Qes: 0.502 • Qts: 0.462• Xmax: 0.4"• Sealed box: 1.2 cu. Ft.• Ported box: 2 cu.. Ft.• Tuning: 40Hz• Port Size: 4”(dia)x8.75”(length)• # of ports:1• Mounting Depth: 6.25”You have been all over the place with equipment from here and there, lets take a step back before you just keep throwing more and more equipment at us. What are your goals, your budget on amp, speakers, front stage, electrical upgrades, etc? I wouldnt get a sub with those T/S Parameters.Thanks jay-cee, you are right, I'm kinda going crazy all over the place tryin to make everything fit into my budget and the whole time the quality of product is getting worse and worse. I am going to slow down and concentrate on obtaining one piece at a time so I can maintain the integrity of the overall system. No sense in putting good money with a bad product, just to have to spend more money later to replace it with what I should have bought in the first place. Thanks to all for your patience.
October 29, 200916 yr Admin Looking for thoughts on specs. I don't know a lot about T/S parameters and all, so looking for some insight. Leaving out brand and model for unbiased opinions. Thanks for any input.1800 watts power handling• 800 Watts RMS• 200 oz. magnet• 2” BASV voice coil• SPL 91 dB• Fs: 36 Hz• Vas: 1.91 cu.ft.• Qms: 5.71 • Qes: 0.502 • Qts: 0.462• Xmax: 0.4"• Sealed box: 1.2 cu. Ft.• Ported box: 2 cu.. Ft.• Tuning: 40Hz• Port Size: 4”(dia)x8.75”(length)• # of ports:1• Mounting Depth: 6.25”You have been all over the place with equipment from here and there, lets take a step back before you just keep throwing more and more equipment at us. What are your goals, your budget on amp, speakers, front stage, electrical upgrades, etc? I wouldnt get a sub with those T/S Parameters.Thanks jay-cee, you are right, I'm kinda going crazy all over the place tryin to make everything fit into my budget and the whole time the quality of product is getting worse and worse. I am going to slow down and concentrate on obtaining one piece at a time so I can maintain the integrity of the overall system. No sense in putting good money with a bad product, just to have to spend more money later to replace it with what I should have bought in the first place. Thanks to all for your patience.
October 29, 200916 yr curious, what woofer is that? I mean a piece of junk it seems more or less, but curious where you found it?
