October 29, 200916 yr I'd be more protective of those wires too. At a recent competition, someone's interior almost caught on fire because something was wrong with the wire outside the car. But good build and damn those amps are big.humm anyone know where i can get them rubber things? But some of the holes are realy big. so i need somthing to work. Should i put rubber pipe tubing around them at the holes?I would try to get some wire loom and black tape it all around. that may help with protection. the factory does the same thing with under the hood wiring.
October 29, 200916 yr Love the base and how clean it looks. It has a nice reflective sheen to it. Lookin real good so far.
October 29, 200916 yr Author Love the base and how clean it looks. It has a nice reflective sheen to it. Lookin real good so far.thanks. The paint is black magic gloss. Go find it
October 29, 200916 yr Wire the amps up to the batteries and stop bull shiting, naw Im just playing (coming along nicely).
October 29, 200916 yr Author Wire the amps up to the batteries and stop bull shiting, naw Im just playing (coming along nicely).lol. Its time to do my buss bars. 1/2 inch thick, 2 inchs wide Alumm
October 30, 200916 yr yea you puss lets get this going!!!! do i need to come up there and do it for you??? lol
October 30, 200916 yr Author yea you puss lets get this going!!!! do i need to come up there and do it for you??? lolyes u should. that would be kool. well i cant do anything today. i gota work 13 hours
October 31, 200916 yr Author Voltage Reset Point. You like that dont you! That turns you on! lol2 Ohm Load. 1 Ohm per board
November 2, 200916 yr you begin to notice how dedicated a install might be by the amount of work put into the electrical aspect of it as well as all the small details.I have looked at quite a few installs over the years, but after doing a few of my own and attempting to replicate what i have seen, either physicaly or finacially , it gives me a greater respect for installs of this stature.while granted, each aspect seems simple enough, it is a true challange to create a full package.I really am taking second and third looks at alot of installs that are done right, attemting to gather those needed details in order to better mine.thanks for the numerous pics.... it helps out alot, and is apppreciated greatly.keep it coming,chopIAK
November 2, 200916 yr Author you begin to notice how dedicated a install might be by the amount of work put into the electrical aspect of it as well as all the small details.I have looked at quite a few installs over the years, but after doing a few of my own and attempting to replicate what i have seen, either physicaly or finacially , it gives me a greater respect for installs of this stature.while granted, each aspect seems simple enough, it is a true challange to create a full package.I really am taking second and third looks at alot of installs that are done right, attemting to gather those needed details in order to better mine.thanks for the numerous pics.... it helps out alot, and is apppreciated greatly.keep it coming,chopIAKyeah thats kool. And glad to help with all the pics lol.
February 7, 201015 yr What Did You Use TO Paint The Bottom Piece Of Wood That Lays Underneath The Box Which Is Laying On The Carpet Of YOur Car.I LOVEE that Finish
February 7, 201015 yr What Did You Use TO Paint The Bottom Piece Of Wood That Lays Underneath The Box Which Is Laying On The Carpet Of YOur Car.I LOVEE that Finish that's been mentioned twice..."The paint? The paint color is black magic gloss (water base). White primer (water base)"
February 7, 201015 yr So for the Base He Used A Primer White (Water Base) Followd by Black Magic Asphalt Paint Like This One..?
February 10, 201015 yr Author So you've gotten rid of the 4 hdc 15s and the 2x aq2200D's?YesAs of right now im working on some detals to my next system coming very soonThinking 4 15'', 4 18'', or 3 18'' Fi BTL Fully Loaded. Thing is I need alot of space for them woofer with the amps and battartys.Amps could be 1 AQ20K, 3 AQ3500.1D, or 4 AQ3500.1D (Rated 4300rms @1 ohm 14.4v 1% THD.)Also Going with Powermaster d3100s and a 2d Dc power alt.
February 11, 201015 yr So you've gotten rid of the 4 hdc 15s and the 2x aq2200D's?YesAs of right now im working on some detals to my next system coming very soonThinking 4 15'', 4 18'', or 3 18'' Fi BTL Fully Loaded. Thing is I need alot of space for them woofer with the amps and battartys.Amps could be 1 AQ20K, 3 AQ3500.1D, or 4 AQ3500.1D (Rated 4300rms @1 ohm 14.4v 1% THD.)Also Going with Powermaster d3100s and a 2d Dc power alt.Sick, stick with the 4 15s. A 12 cu. ft. box tuned low with 4 15s would slam pretty good, especially with 20k rms going to em.
February 11, 201015 yr Author So you've gotten rid of the 4 hdc 15s and the 2x aq2200D's?YesAs of right now im working on some detals to my next system coming very soonThinking 4 15'', 4 18'', or 3 18'' Fi BTL Fully Loaded. Thing is I need alot of space for them woofer with the amps and battartys.Amps could be 1 AQ20K, 3 AQ3500.1D, or 4 AQ3500.1D (Rated 4300rms @1 ohm 14.4v 1% THD.)Also Going with Powermaster d3100s and a 2d Dc power alt.Sick, stick with the 4 15s. A 12 cu. ft. box tuned low with 4 15s would slam pretty good, especially with 20k rms going to em.we will see
