im so dumb when it comes to port calculations and shit. i just want one port on top of the box. what side should i put it on? drivers side? and mac. last time bro. 41 wide 20 tall and 16 deep. do work
port along passengers side
  • Replies 422
  • Views 40.3k
uh, i sorta fast forwarded through the build log, but missed the change in plans..
sorry, but catch me up to date on your box.... this one is going behind the seat , in the cab?
are you still planning the blow thru?
pics of the completed big three?
chop
no blow thru. figured i would just rock the shit out of the cab :). yet to do the big 3 but its extremely easy to do on the v6 vortecs so ill get around to it.
right on. did you do any deadening to the cab?
is 16" deep with the interior panel still in place, is the rear seat still in?
Hows this look boys?
port 3.5 wide 11.75 back and the L part is 8
CUT OUT DIMENTIONS
Top 38x14.5
Bottom 40.5x14.5
front and back 41x20
sides 20x16
Port A 16x11.75
Port B 16x8
i dont have rear seats. and the interior panel is still in, i didnt feel like tearing the truck apart just in case if i change the setup sometime in the future. And no deadning. i hope soon tho. i plan on bagging my truck so thats going to be a hell of a setback.
CUT OUT DIMENTIONS
Top 38x14.5
Bottom 40.5x14.5
sides 20x16
Port A 16x11.75
Port B 16x8
Dimensions don't look right at all.
are you useing re?
i am getting different demensions.
what tunning was you wanting?
it would be sweet if you boys could help me out.
np, i can help with the basics.....
first off, do you have access to re's box designer....
RE Enclosure Calculator
have you used it or use it currently?
yeah ive used it before i know how. im pretty sure thats where mac n chesse got em from.
How does this look?
Those are the cut out dims
Front and Back:41x20
Top:35.25x14.5
Side:19.25x14.5
Side:18.5x14.5
Port width:5
Port L1: 13.5x14.5
port l2: 8x14.5
i will look in two secs, my mouse is on fire hear, lol.....
i have five windows open, plus texting chicago fan and rattlebox....
i guess the re calc just isnt working with me. scott told me it would be fine to run smaller than 5 cubes. bromo you wanna make some dims for me then please?
the numbers you have posted would reflect the 41 x 16 x 20 that you are after.....
the port length and width you listed would tune you at 32.77hz. and give you a volume of 4.8 cubes.....
i do not know how much air space you need yet, i gotta look that up, or you can tell me.
Unless your gonna run ungodly amounts of power I dont see the point of going below recommended box size, you should just get a smaller sub it will perform better in a 4.5-5 ft^3 since that is the room you have for it. Just my .02
you gotta give us some more space. them panels will come out easy enough without tearing them to shit. and they are easy to replace from the junkyard if you do.
well. when iwas in vegas scott told me it would be fine if i put my 18 in my truck with those dims.. he actually sat in my truck and said yeah you can easily fit your btl in here. and if i were to take the panling out i wont even get 1/2 and inch of more room. ill go measure and see what i can get.
the 20" high, where does that put the top of the box?
will you be in any comps?
is 41 wide as tight as you can go?
yeah see what you can squeeze in there....
numbers don't lie....
we gotta get you more space from somewhere.
you don't want a skimpy box for that beast.
