Posted October 28, 200917 yr Admin IPB came through and was able to adjust the emoticon list so that we can access all of them from the reply box again!! So to see all of the emoticons, just click the smilie face icon above the text input box, (the emoticon list will pop up on the right), then click the "show all" link at the bottom of the list to see the entire set.
October 28, 200917 yr Author Admin And I thought it was my computer or somethin.No, it was just a slight adjustment since the upgrade.
October 28, 200917 yr IPB came through and was able to adjust the emoticon list so that we can access all of them from the reply box again!! So to see all of the emoticons, just click the smilie face icon above the text input box, (the emoticon list will pop up on the right), then click the "show all" link at the bottom of the list to see the entire set. ?????????????????????????
October 28, 200917 yr Author Admin That is odd, it is working here. Maybe log out and log back in. If not, try the full reply, see if it is showing there.
October 28, 200917 yr Author Admin !but i'm having the same problem as pengIn both the fast reply and normal reply?
October 28, 200917 yr Author Admin Double checked things on the ftp, and all looks good on the back end. Waiting to see what the support site says.
October 28, 200917 yr That is odd, it is working here. Maybe log out and log back in. If not, try the full reply, see if it is showing there.No dice!but i'm having the same problem as pengIn both the fast reply and normal reply?Indeed
October 29, 200917 yr Author Admin That is odd, it is working here. Maybe log out and log back in. If not, try the full reply, see if it is showing there.No dice!but i'm having the same problem as pengIn both the fast reply and normal reply?IndeedTalking with IPS now, there might be a conflict with a directory on the back end. Either way, working to fix it.
October 29, 200917 yr O M G ....... i am in shock... did not even know .... the smilies are al back....... i will be ruined for weeks to come!!! thanks denim !!!!
October 29, 200917 yr Author Admin link shows up, but doesn't workAre you using the stock skin? If so, that could be why.
October 29, 200917 yr I'm using the grey theme and the link is there, it just doesn't work. It DOES however work when I switched to the dark theme..... I like grey better though
