after doing a "uninstall" i ended up scuffing the surround on the subs. one is pretty bad (atleast i think). what can i do to fix this? just silicon it? it did not punture the sub its just looks bad.
You could just silcon it and use some touch up paint. I suppose, if it really bothers you that much.
Post a picture so someone can give you some advice on if its bad or not so bad scuff and how to properly fix it.
In order to really know what to apply to look the best, we should know if the surround is rubber or foam?
hmm.. turns out its not as bad as i thought. its the foam. and i cant really get it to show on my phone camera.
I have an idea! How about you let them play, and if the surround tears then you buy a replacement surround for 4 bucks!! fing05.gif
