Posted November 2, 200916 yr I'm in the process of trying to decide between these 2 amps :MTX TE1501D Elite $339USAMPS MD-2D $319The car will be a daily driver.The subwoofer will be :RE AUDIO 15" SEX-or-RE AUDIO 15" SXI've heard the MD-2D isnt very clean, but I do love USAMPS from my expierence in the past they are GREAT amps, but for my pricerange these are the 2 amps im looking at. I have no expierence with MTX, so I ask you what is a better amp?What are the Pros and Cons of both. Also would a MD-2N be overkill for a 15" RE SXX? Would an MD-1DN do the job?
November 2, 200916 yr have you considered a sundown amp? like a SAZ2000 or SAZ1500 or even a SAE1200d (280 bnib)??and i have never personnaly used either of those amps! but my buddy has used the mtx one and i didn't mind it! i actually thought it was pretty good!! so from my buddies point of view go with the mtx! Edited November 2, 200916 yr by CrazyKenKid
November 2, 200916 yr Admin I have not read any complaints about the MD-2D, the MD-1D is plenty of power for most installs.
November 2, 200916 yr I'm in the process of trying to decide between these 2 amps :MTX TE1501D Elite $339USAMPS MD-2D $319The car will be a daily driver.The subwoofer will be :RE AUDIO 15" SEX-or-RE AUDIO 15" SXI've heard the MD-2D isnt very clean, but I do love USAMPS from my expierence in the past they are GREAT amps, but for my pricerange these are the 2 amps im looking at. I have no expierence with MTX, so I ask you what is a better amp?What are the Pros and Cons of both. Also would a MD-2N be overkill for a 15" RE SXX? Would an MD-1DN do the job?i say the mtx< those amps do put out more than rated, i have eve seen one of those amps put out 2k +
November 2, 200916 yr i have a 1501d mtx good amps and they have anti clip circuit to protect speakers.
November 3, 200915 yr Author i have a 1501d mtx good amps and they have anti clip circuit to protect speakers.Wow that is very interesting, can you show me a link to the data that states that feature? That would definitely be a deciding factor for a Daily Driver Setup!I called USAMPS today and spoke with them about the 15" SXX Dual 2-ohm Sub woofer and they recommended :6.0cft Ported Enclosure tuned to 35hz1500watts RMS at 1ohmBTW another thing I noticed the MTX lists some nasty THD and SN Ratio Specs :MTX TE1501D :# THD at 4-Ohm RMS Power: <0.5% <---that's at 4ohms and already terrible imagine at 1ohm!# Signal to Noise Ratio: 69 dB <---thats not on par for a new age ampUSAMPS MD-2N :THD at 1ohm 0.03%Signal to Noise ratio: 89dB Edited November 3, 200915 yr by Steveman09
