Posted November 5, 200916 yr ok we hooked my friends BTL to a saz-3000 today and as we where playing different songs we heard it popping. is that because its too many watts for the sub?or is it just how its tuned. allso its at 1ohm what do you people recomend to leave it at 1ohm or up to 2ohms???
November 5, 200916 yr I think your bottoming it out, on the back plate. How are your controls on your amp set?
November 5, 200916 yr Sending it more watts than what it's rated shouldn't effect it to where it's 'popping'. Either it's bottoming out, or you need to ground your RCAs or get some new ones what deckare you using. I had a popping sound on my AQs and found out the ground on my RCA output from my deck was lose.
November 5, 200916 yr Dude...you're sending it 1000 watts more than it's rated.Lolz. There are people who run 4k+ rms with no problems. Its most likely that the box is too big, and it can't mechanically handle all 3000w
November 5, 200916 yr Playing below tuning frequency of the enclosure...with no subsonic filter on...or it is not set properly for the tuning of the enclosure...Speakers are stupid..they do EXACTLY what you tell them to do.
November 5, 200915 yr Popping is a very, very general term. We need much more info like more specifically how it sounds, when does it happen, etc.
November 5, 200915 yr ok we hooked my friends BTL to a saz-3000 today and as we where playing different songs we heard it popping. is that because its too many watts for the sub?or is it just how its tuned. allso its at 1ohm what do you people recomend to leave it at 1ohm or up to 2ohms???Since it is a dual 2 ohm subwoofer wire it at 1 ohms, and we need more info from you man. Either the box is the problem or your settings could be at fault or both, follow these settings so you wont mess up anything on that subwoofer:Head Unit SettingsBass Boost/Exend = OffLoud/Loundness = OffSub Level: + whatever yours goes up to minus a few whatever your preferenceBass = 0 or lower, whatever your preferenceAmp SettingsGain = Set with DMM (with a 50Hz test tone and at subs rms or amps rms whichever is lower), no more than 50-60% if you dont have one.LPF = 100Hz or lower whatever your preferenceBass Boost = OffSSF = 1-5 Hz lower than box tuning, or until subs start to reach its excursion level.
November 5, 200915 yr Author allright i will answer everyones questions later on when he comes over so we can look at it again and ill have pictures up too
November 6, 200915 yr allright i will answer everyones questions later on when he comes over so we can look at it again and ill have pictures up tooi would bet turn up ssf.or broken box.
November 7, 200915 yr allright i will answer everyones questions later on when he comes over so we can look at it again and ill have pictures up tooi would bet turn up ssf.or broken box.You think it's unloading?
