Posted November 6, 200916 yr Ok so I'm in the market to buy another amp for my new sub setup.My Car is a 94 Legend Coupe6.5" Infinity Kappa Fronts6x9' Infinity Kappa RearsUSAMPS XT1600.4 V2 Amp Running the Kappa'sNow I'm needing to power (1) 15-inch RE SXX D2 Subwoofer in a 35hz Ported 3cft Custom Fiberglass/Wood Spare Tire EnclosureThese are the amps im looking at :USAMPS MD-2D 1500rms@1ohm $319.99MTX TE1501D 1500rms@1ohm $369.99Kicker KX1500.1 1500rms@2ohms $359.99 (if I get this amp I would buy the RE SXX D4 of course)So what amp should I get?The car is a daily driver, so efficiency and SQ is important to a certain extent but not a MUST, im willin to sacrifice some efficiency for power.The Alternator is a stock 110amp right now, but im upgrading it to a 200amp.The battery right now is a Dry Cell Exide Orbital Deep Cycle, i'm planning to add a Kenitek HC2000 in the trunk for the amps. Edited November 6, 200916 yr by Steveman09
November 6, 200916 yr Just go with what fits your budget, they all are great amps. The only thing I would say would be the Kicker. Apparently has one setting on it, that is set and you can't set it. I can't remember it for some reason, at the moment.... lol
November 6, 200916 yr Just go with what fits your budget, they all are great amps. The only thing I would say would be the Kicker. Apparently has one setting on it, that is set and you can't set it. I can't remember it for some reason, at the moment.... lolKickers have a set subsonic filter on them so you would have to build your enclosure if ported around the range or more (so it leaves you few options tuning frequency wise).
November 6, 200916 yr Yes, knew it was something like that but, didn't feel like giving out false info.
November 6, 200916 yr What is your budget for this new amp?If I have to pick from those three, it would be the US. If you dont mind other options, you should check out Sundown Audio. They are right here on this forum and make great amplifiers.
November 6, 200916 yr Another option you may want to look at is the Sundown SAE-1200 v.2! A very underrated amplifier that will do rated and then some. On sale now for $280 shipped!
November 6, 200916 yr Of those 3, I'd get the md2d but there are other amps you can get for a better price.
November 6, 200916 yr Another option you may want to look at is the Sundown SAE-1200 v.2! A very underrated amplifier that will do rated and then some. On sale now for $280 shipped!x2, I forgot about this amplifier (the best one of them all, very beasty amp).
November 6, 200916 yr There are quite a few used SAZ-1500's in the For Sale section. Highly recommend them, practically bulletproof amps and great customer service.
November 6, 200916 yr There are quite a few used SAZ-1500's in the For Sale section. Highly recommend them, practically bulletproof amps and great customer service.x2, or you can go to db-r.com for more Sundown equipment if you dont want to buy new.
November 7, 200916 yr Author Thanks for all the replies, I think im going to go with Sundown SAZ-1500D and if that doesn't work out im going to get the USAMPS MD-2D
November 7, 200916 yr Author i think you will stick with your sundown once experiencedNice!I will post pics of the install up once its all finished!
November 7, 200916 yr MB Quart dsc 2000d $308 sonicelectonixGood amp but the sundown is better and cheaper, very underrated amp (a 1200 watt amp that puts out 1700 watts, can you say ridiculous).
November 8, 200916 yr Author MB Quart dsc 2000d $308 sonicelectonixGood amp but the sundown is better and cheaper, very underrated amp (a 1200 watt amp that puts out 1700 watts, can you say ridiculous).Ok well its done! I bought a SUNDOWN SAZ-1500D with light use for $320 off a member on here.Now to order the SUB!RE 15' SXX or Sundown Nightshade 15' D2?
November 8, 200916 yr Ok well its done! I bought a SUNDOWN SAZ-1500D with light use for $320 off a member on here.Now to order the SUB!RE 15' SXX or Sundown Nightshade 15' D2?Nightshades aren't in production anymore if your wanting a new one (and the V2's aren't due for a while). FYI. Might have to hunt for a 2nd hand one around the traps.Jono
November 8, 200916 yr Author Ok well its done! I bought a SUNDOWN SAZ-1500D with light use for $320 off a member on here.Now to order the SUB!RE 15' SXX or Sundown Nightshade 15' D2?Nightshades aren't in production anymore if your wanting a new one (and the V2's aren't due for a while). FYI. Might have to hunt for a 2nd hand one around the traps.JonoI found a 15 nightshade d2 on the forums, but I wanna make sure its a better quality sub than a RE SXX 15 D2, I heard someone say the Nightshades have issues with the voice coil wires coming unglued?
