Posted November 6, 200917 yr If I drill a whole just big enough for the speaker wire to pass through what should I use to seal up the whole so no air leaks out? Thanks
November 6, 200917 yr If I drill a whole just big enough for the speaker wire to pass through what should I use to seal up the whole so no air leaks out? ThanksI used silicone, just taped up both sides so I could stay still until it cured worked fine for me (but others may chime and tell you what they would use).
November 6, 200917 yr Author So would this workhttp://www.homedepot.com/Kitchen/h_d1/N-5yc1vZ1xg4Zar4i/R-100097524/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
November 6, 200917 yr So would this workhttp://www.homedepot.com/Kitchen/h_d1/N-5yc1vZ1xg4Zar4i/R-100097524/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053Yeah that should do the trick but hold on a minute before going out to get it to see if someone has anymore ideas that may be better but that worked well for me.
November 6, 200917 yr Author Yeah that should do the trick but hold on a minute before going out to get it to see if someone has anymore ideas that may be better but that worked well for me.I will patience is key FTW
