Posted November 7, 200917 yr ok so i have heard that i need to do the big three and not get a capi have a few questions regarding this thoughi have a bmw and the battery is in the trunk, so do i still need to run the alt to batt wire with fuse? i mean stock is a 4 gaugeand since stock is 4 gauge everywhere will the big three help at all? or do i just need to buy a new batterymy car dims a lot with a small 300w system and i have a new battery and alternatoreverything is grounded correctly and i run 4 gauge and 16 for the subsPatrick
November 7, 200917 yr I moved this to the electrical section.If you are getting dimming with only 300 watts there may be something wrong. What are the stock alternator and battery sizes?With only 300 watts 4 gauge is fine.
November 7, 200917 yr Yup, that is really weird that 300 watts make you dim. This is more than a big3 problem. Have you had anyone check the alternator and/or battery? And make sure those ground points are sanded really well, and that they are the metal of the chassis and not something else.
November 7, 200917 yr You should do a load test on the alt. 300 watts is not nearly enough to do that.
November 7, 200917 yr What happens when you have the accessories and air on full blast without the music playing? Do you still get dimming?
November 7, 200917 yr Author What happens when you have the accessories and air on full blast without the music playing? Do you still get dimming?thats how i blew my alti had the air radio subs windshield wipers on full and all lights on and it diedits brand new battery and alteverything is grounded correctly and i even did a battery ground on the batt to chassis wirethe battery is really big but i dont know the size without taking it outPatrick
November 7, 200917 yr Even though the alt is new, is it enough? Maybe with all those systems running, it cant handle it. What is the amp rating on the alt you put in? The OEM alt might not be enough. But with only 300 watts, thats sounds pretty crazy doesnt it?
November 7, 200917 yr Author Even though the alt is new, is it enough? Maybe with all those systems running, it cant handle it. What is the amp rating on the alt you put in? The OEM alt might not be enough. But with only 300 watts, thats sounds pretty crazy doesnt it?120 amp i think, at least thats what it says on bavauto.com
November 7, 200917 yr No way should you be having problems with a 120 amp alternator. Something else is going on then.The last alt may have just died because it was old and wearing out anyways, regardless of having all those things on. But if the new one is still bad, either the alternator has a factory defect or something is really pulling current other than the stereo.
November 7, 200917 yr Author No way should you be having problems with a 120 amp alternator. Something else is going on then.The last alt may have just died because it was old and wearing out anyways, regardless of having all those things on. But if the new one is still bad, either the alternator has a factory defect or something is really pulling current other than the stereo.that was my thought exactly, i mean the alt was 6 years oldbut the car was checked over by a professional car audio installer and it was fine and like i said it has 4ga wireto top it all off my friend has a 2000W system in his 3series (with same battery) and he has no dimming at all
November 7, 200917 yr No way should you be having problems with a 120 amp alternator. Something else is going on then.The last alt may have just died because it was old and wearing out anyways, regardless of having all those things on. But if the new one is still bad, either the alternator has a factory defect or something is really pulling current other than the stereo.that was my thought exactly, i mean the alt was 6 years oldbut the car was checked over by a professional car audio installer and it was fine and like i said it has 4ga wireto top it all off my friend has a 2000W system in his 3series (with same battery) and he has no dimming at allGetting your car checked by a supposedly professional car audio installer means nothing nowadays especially if it deals with electrical or voltage problems, take your car to someone who knows or specializes in electrical work (be smart about how you take care of your car especially if you want it to last long).How about you get a volt meter so you can watch your voltage (Im pretty sure there is more in your car than that if its dimming, what other car audio equipment do you have in there?). Buy a digital multi meter and test amp and battery, with car on and car off. I hope when your sitting idle, you turn your system down. Do you play your system with car off alot?
November 7, 200917 yr Author No way should you be having problems with a 120 amp alternator. Something else is going on then.The last alt may have just died because it was old and wearing out anyways, regardless of having all those things on. But if the new one is still bad, either the alternator has a factory defect or something is really pulling current other than the stereo.that was my thought exactly, i mean the alt was 6 years oldbut the car was checked over by a professional car audio installer and it was fine and like i said it has 4ga wireto top it all off my friend has a 2000W system in his 3series (with same battery) and he has no dimming at allGetting your car checked by a supposedly professional car audio installer means nothing nowadays especially if it deals with electrical or voltage problems, take your car to someone who knows or specializes in electrical work (be smart about how you take care of your car especially if you want it to last long).How about you get a volt meter so you can watch your voltage (Im pretty sure there is more in your car than that if its dimming, what other car audio equipment do you have in there?). Buy a digital multi meter and test amp and battery, with car on and car off. I hope when your sitting idle, you turn your system down. Do you play your system with car off alot?this guy is the best in my area and highly recommended, and happens to be a family friend, and i get it checked by the guy who works on my cari will play around with the meter, since i dont have a built in volt meter in my carand i never play it with my car off, i have seen too many of my friend's batteries die because of thatwell its just the stock HU, speakers (replaced but still stock specs) and stock ampi do rum 55W HIDs, but this was happening before i added thosei just added the subs, no other audio equipment
November 7, 200917 yr Go buy a volt meter like most of us who didnt have one come factory and install it. Well I understand what your saying about your installer but if you want to listen to someone who cant even tell you why your lights are dimming off of 300 watts and he is supposed to be the best then that should tell you something. But its your car and not mine, so shortcut and see where it gets you but I would take my shit to BMW or someone else who is certified before the problem continues and gets worse, just my .02 but to each its own.
November 7, 200917 yr Author Go buy a volt meter like most of us who didnt have one come factory and install it. Well I understand what your saying about your installer but if you want to listen to someone who cant even tell you why your lights are dimming off of 300 watts and he is supposed to be the best then that should tell you something. But its your car and not mean, so shortcut and see where it gets you but I would take my shit to BMW or someone else who is certified before the problem continues and gets worse, just my .02 but to each its own.i have a volt meter and a friend who is an electrical engineer, ill look at it tomorrowthanks for the help
November 10, 200916 yr Go buy a volt meter like most of us who didnt have one come factory and install it. Well I understand what your saying about your installer but if you want to listen to someone who cant even tell you why your lights are dimming off of 300 watts and he is supposed to be the best then that should tell you something. But its your car and not mean, so shortcut and see where it gets you but I would take my shit to BMW or someone else who is certified before the problem continues and gets worse, just my .02 but to each its own.i have a volt meter and a friend who is an electrical engineer, ill look at it tomorrowthanks for the helpHas anyone thought he might be running a highly underrated amp?What amp are you running?And if it isnt underrated, maybe its bad and pulling more current then it should, I had that problem awhile back.
November 10, 200916 yr Go buy a volt meter like most of us who didnt have one come factory and install it. Well I understand what your saying about your installer but if you want to listen to someone who cant even tell you why your lights are dimming off of 300 watts and he is supposed to be the best then that should tell you something. But its your car and not mean, so shortcut and see where it gets you but I would take my shit to BMW or someone else who is certified before the problem continues and gets worse, just my .02 but to each its own.i have a volt meter and a friend who is an electrical engineer, ill look at it tomorrowthanks for the helpHas anyone thought he might be running a highly underrated amp?No, not it.If it were a raw class A then perhaps, but I am sure he'd tell us if he spent that much on it.BTW cheap HID's can sometimes dim extremely easy. The BM'er in really working form should have no problems with what he has. Having it checked out by someone who specializes in electrical is a logical next step. DEFINITELY DO NOT buy a cap now.
November 10, 200916 yr Author im going to have it checked out soonthe HIDs dont really dim, its more the fog lights, and they are only 35Wthe amp is a mono 300W Rockford Fosgate (like the p300-1 i think)
November 10, 200916 yr Interesting, not sure why you are running your fogs when it isn't foggy. Measure your voltage at the fogs and at the battery and see if they are different when this dimming occurs.
November 10, 200916 yr Author i only run them at night (b/c they are bright) and when its foggyi went to the local Interstate battery warehouse (thats who makes my current car battery) and they checked it and the alt and stuff like that and they said everything was fine and the alt was putting out 14.2Vthey said its just gonna dim a little and not to be worried, and if anything add a second battery (and they were not saying that bc they sell batteries)
November 11, 200916 yr im going to have it checked out soonthe HIDs dont really dim, its more the fog lights, and they are only 35Wthe amp is a mono 300W Rockford Fosgate (like the p300-1 i think)There ya go Fogate P300-1 is a very underrated amp, I wouldn't doubt when pushing it the lights dim a little bit!I used to have a old Punch Turtle Shell amp that was VERY underrated and it made my lights dim with a 110A ALT.
November 11, 200916 yr I doubt its that under-rated.Here is a review I pulled off google : Price Paid: $200.00 from HH GregYear / Model Reviewed: p3001Summary:I like this amp.... ive ran about 3 different combos off of this amp.... at one point i had it pushing two 12 inch memphis DVC's and and audiobahn 15 and it banged.... right now i have it hooked up to a 12inch P3 rockford and it can the sub can barely handle it.... so i dont know if i just lucked out or what but the birth certificate on my amp rates it at 1137 watts and ive blown enough subs to think its true....Strengths:lots of power.... tight hitting.... doesnt heat up....Weaknesses:having trouble finding something other than a rockford T1 Power that i can use it to powerSimilar Products Used:MTX Memphis Audiobahn JLSeems that guys is pushing 1137watts! Thats definitly enough to dim lights....I used to have a 3001 Punch that had a birthsheet of 680watts, so I'm thinking his is underrated as well.What OHM load are you running it at? That makes a big difference too, ive run mine at 1-ohm before and it pushed really well, but thats under what its rated since its 2-ohms officially.
November 11, 200916 yr Author I doubt its that under-rated.Here is a review I pulled off google : Price Paid: $200.00 from HH GregYear / Model Reviewed: p3001Summary:I like this amp.... ive ran about 3 different combos off of this amp.... at one point i had it pushing two 12 inch memphis DVC's and and audiobahn 15 and it banged.... right now i have it hooked up to a 12inch P3 rockford and it can the sub can barely handle it.... so i dont know if i just lucked out or what but the birth certificate on my amp rates it at 1137 watts and ive blown enough subs to think its true....Strengths:lots of power.... tight hitting.... doesnt heat up....Weaknesses:having trouble finding something other than a rockford T1 Power that i can use it to powerSimilar Products Used:MTX Memphis Audiobahn JLSeems that guys is pushing 1137watts! Thats definitly enough to dim lights....I used to have a 3001 Punch that had a birthsheet of 680watts, so I'm thinking his is underrated as well.What OHM load are you running it at? That makes a big difference too, ive run mine at 1-ohm before and it pushed really well, but thats under what its rated since its 2-ohms officially.oh wow that would make sense then, i just hope i dont blow my 2 rockford punch P1 12" subsim running 2 ohm
November 11, 200916 yr Edit: Just read that again.If this amp is a class a/b amp then maybe the current draw from the battery is about the same as a class d amp rated for double that of the A/B amp.
November 11, 200916 yr The new punch amps aren't as underrated as the old ones. Back in the day of the old gray waffle iron heat sinks they were underrated by nearly 100%. But not anymore. Rockfords have always also been a bit current hungry. Yep, I just looked it up, and as per Rockford's website, that amp is only 65% efficient because it's a class A/B. So you're pulling about 500 watts from the electrical system. Are you clipping the hell out of it too?
