Posted November 11, 200916 yr So I'm going to running the new XCON 15' D2 Subwoofer in a custom spare tire enclousure and I'm torn on SEALED OR PORTED@35hz?The car's goal is daily driver ""SQL"".SUNDOWN SAZ-1500D is the amp with MORE than enough upgraded electrical to support it.
November 11, 200916 yr Admin So I'm going to running the new XCON 15' D2 Subwoofer in a custom spare tire enclousure and I'm torn on SEALED OR PORTED@35hz?The car's goal is daily driver "SQL".SUNDOWN SAZ-1500D is the amp with MORE than enough upgraded electrical to support it.I vote ported. Tune a bit lower if you can around 31-33hz and you'll be very very happy with your new set up
November 11, 200916 yr Author So I'm going to running the new XCON 15' D2 Subwoofer in a custom spare tire enclousure and I'm torn on SEALED OR PORTED@35hz?The car's goal is daily driver """SQL""".SUNDOWN SAZ-1500D is the amp with MORE than enough upgraded electrical to support it.I vote ported. Tune a bit lower if you can around 31-33hz and you'll be very very happy with your new set up Hmm what size enclosure do you rec. for 31-33hz?I'm trying to find the perfect size towards the smaller end of the spec to save space yet still get some output.
November 11, 200916 yr Admin you can find more info here: http://www.soundsolutionsaudio.com/index.php/product-information/xcon.html
November 11, 200916 yr Author Ported: 3.0-3.25ft^3@26-33Ported: 4.0ft^3 @ 26-33hz optYeah im just a little worried about having enough spare in the spare tire area for 3.25cft
November 11, 200916 yr If that's a concern, you NEED to go out and measure it. Otherwise none of our suggestions are worth anything if it won't fit.
November 11, 200916 yr Admin If that's a concern, you NEED to go out and measure it. Otherwise none of our suggestions are worth anything if it won't fit.Exactly. And if you cannot fit ported, the Xcon is tremendous in a sealed box.
