Posted November 12, 200916 yr If i have a bluetop under the hood big three in two runs of 0ga (basically, doubling up), one (or two, working out kinks) 250-300A alts, and 4-6 runs of 0ga to the back, to three(or four, if i get dual SAZ-4500D's) D3100's how short would i theoretically have to have the dual 0ga to the SAZ-4500D(or two....Not sure) to get the most out of the batts and amp, mostly for comp concerns?holy crap, lotsa wire!Thanks, -Chris
November 12, 200916 yr Just as short as possible. There's no real answer since you can't go any shorter than your install will allow. If you have your amps 6 feet away how can we tell you to make your wires 4 feet long? Just put the amps as close as feasible to the batteries. That's it.
November 12, 200916 yr Just as short as possible. There's no real answer since you can't go any shorter than your install will allow. If you have your amps 6 feet away how can we tell you to make your wires 4 feet long? Just put the amps as close as feasible to the batteries. That's it.x2,
November 13, 200916 yr Author Just as short as possible. There's no real answer since you can't go any shorter than your install will allow. If you have your amps 6 feet away how can we tell you to make your wires 4 feet long? Just put the amps as close as feasible to the batteries. That's it.x2, x3 Lol so obvious... Thanks anyway
