Posted November 16, 200916 yr I'm currently building an enclosure for 1 Fi BL, (15") and I was wondering, which box will better suit the sub, (both will be tuned to 32Hz).4cuft4.9cuftSee signature for car and current setup info.Thanks
November 17, 200916 yr I'm currently building an enclosure for 1 Fi BL, (15") and I was wondering, which box will better suit the sub, (both will be tuned to 32Hz).4cuft4.9cuftSee signature for car and current setup info.ThanksIt depends on your prefernces but since they will be tuned the same go for what fits and you have the room left over you want. It will be a little difference but not to much, maybe a little more of a low end with the 4.9ft^3. Just my .02
November 17, 200916 yr Author Made a recent compromise: 4.45cuft. If you must know... the amp is a volfenhag. Ok, it's out and I know it sucks but I was young and easily misled... Either way, manual says it puts out 650 at 1ohm and it's the only choice I got now. Will this amp and box be suitable for the 15 BL? I'm upgrading the amp ASAP, but will it do for now?
November 17, 200916 yr Made a recent compromise: 4.45cuft. If you must know... the amp is a volfenhag. Ok, it's out and I know it sucks but I was young and easily misled... Either way, manual says it puts out 650 at 1ohm and it's the only choice I got now. Will this amp and box be suitable for the 15 BL? I'm upgrading the amp ASAP, but will it do for now?No such thing as underpowering. Clipping, however, can be dangerous.
November 17, 200916 yr Made a recent compromise: 4.45cuft. If you must know... the amp is a volfenhag. Ok, it's out and I know it sucks but I was young and easily misled... Either way, manual says it puts out 650 at 1ohm and it's the only choice I got now. Will this amp and box be suitable for the 15 BL? I'm upgrading the amp ASAP, but will it do for now?That box will be fine as long as it is well built, the amp will do until you get something else just make sure your sending your sub clean signals and not clipped ones. Just my .02 and good luck with install and dont forget to post pictures.Pictures on SSA =
November 17, 200916 yr I ran a Pyramid amp for months. Hahahahaha. I think you should be fine. Im a little curious if that amp would actually not blow up at 1 ohm or if it does rated power.
November 17, 200916 yr Author I ran a Pyramid amp for months. Hahahahaha. I think you should be fine. Im a little curious if that amp would actually not blow up at 1 ohm or if it does rated power.And if it does blow up I'll make sure I have a video of the event lot... but then of course I'll have to get a new amp Thanks for the input everyone.
November 17, 200916 yr Made a recent compromise: 4.45cuft. If you must know... the amp is a volfenhag. Ok, it's out and I know it sucks but I was young and easily misled... Either way, manual says it puts out 650 at 1ohm and it's the only choice I got now. Will this amp and box be suitable for the 15 BL? I'm upgrading the amp ASAP, but will it do for now?That box will be fine as long as it is well built, the amp will do until you get something else just make sure your sending your sub clean signals and not clipped ones. Just my .02 and good luck with install and dont forget to post pictures.Pictures on SSA = Haha and the pack of dancing bananas lol.Are you upgrading the amp anytime soon. If not you could build the box a lil bigger and get more outa it, if you have the room.
November 18, 200916 yr Author Made a recent compromise: 4.45cuft. If you must know... the amp is a volfenhag. Ok, it's out and I know it sucks but I was young and easily misled... Either way, manual says it puts out 650 at 1ohm and it's the only choice I got now. Will this amp and box be suitable for the 15 BL? I'm upgrading the amp ASAP, but will it do for now?That box will be fine as long as it is well built, the amp will do until you get something else just make sure your sending your sub clean signals and not clipped ones. Just my .02 and good luck with install and dont forget to post pictures.Pictures on SSA = Haha and the pack of dancing bananas lol.Are you upgrading the amp anytime soon. If not you could build the box a lil bigger and get more outa it, if you have the room.I'd love to, but I won't have the $$$ for some time.
