Posted June 11, 200521 yr hey guys i have a quick question.what is the benifit of tuning your box closer to the res. freq of the car instead of to the sub? in spl competitions?
June 12, 200521 yr If you tune your box to peak out at the resonant frequency of your car, you get two peaks in one which makes for the loudest possible note in your car. It's late and I dont feel like getting too technical, so I hope this will suffice.
June 13, 200521 yr Author If you tune your box to peak out at the resonant frequency of your car, you get two peaks in one which makes for the loudest possible note in your car. It's late and I dont feel like getting too technical, so I hope this will suffice.<{POST_SNAPBACK}>hey thanks do you think when you gewt a chance you could go into more detail?
June 13, 200521 yr They're called "One Note Wonders". They get crazy loud at their peak, but they suck for music most of the time.
July 14, 200521 yr They're called "One Note Wonders". They get crazy loud at their peak, but they suck for music most of the time.<{POST_SNAPBACK}>Eh?? Your resonant frequency is called a one note wonder?? I think your kind of confused To the origional poster, I will assume you have a general knowlege of enclosures and such. If you do, then you know that any enclosure will have a peak in response, which will usually give a peak in sound levels also. Using this, think of your vehicale basically as another enclosure. With that, you now have another peak in response, which is the res. frequency. It's not too complicated so tere really is no need to get really technical. Better?
