Posted November 19, 200915 yr would the icon 12 work well on 600 watts? gonna be powering it with a rsd600.1box will be 2 cubes tuned to 32 hz Edited November 19, 200915 yr by eggyhustles
November 19, 200915 yr would the icon work well on 600 watts? gonna be powering it with a rsd600.1box will be 2 cubes tuned to 32 hzThe Icon will work well on 600 watts since there is no such thing as underpowering a subwoofer, just send it a clean signal and dont clip the amp (you will be okay). If you want to make the box bigger it would help with the low amount of power you will be sending the Icon.
November 19, 200915 yr Author would the 10 be better in 2 cubes? Edited November 19, 200915 yr by eggyhustles
November 19, 200915 yr Yeah and the box can be around 1.6-18 ft^3, doesnt have to be 2ft^3 but yeah the 10" would be better if 2ft^3 is the biggest enclosure you can fit.
November 19, 200915 yr Admin The Icon will play very nicely with that amplifier. If after port and driver displacement, you have 2 cubes, the 12 will be just fine.
November 19, 200915 yr Admin should sound excellent. I have two icon 10's in my HT on 600/ea and they are just nuts!
November 20, 200915 yr I was running my Icon 15 on 650 watts rms, and it was plying really well.I liked it a lot!
November 27, 200915 yr Omfg I am amazed... I just ordered an icon 12 inch and I plan on doing 2.25 cu ft tuned to 29hz and then use my phoenix gold xenon 1200.1 to power it. But I will set the gain accordingly to give my sub exactly 1000rms. I can't wait. I am so excited to see how this sub performs WITH THE DESIRED RMS rating. OMFG I am excited. Plus this will be my first sub with a ported box and actually built to specs instead of pre fabb box. I am used to a sealed enclosure LOL.im hearing great things about this icon 12 sub. I am stoked...
November 27, 200915 yr What size sub did you get and what size enclosure did you put it in. Glad to hear it worked out for you.
November 27, 200915 yr Author 12" box was 2 cubes after port and sub tuned to 32hz gonna go sealed soon since it's going in my mothers scion Edited November 27, 200915 yr by eggyhustles
November 27, 200915 yr Admin Omfg I am amazed... I just ordered an icon 12 inch and I plan on doing 2.25 cu ft tuned to 29hz and then use my phoenix gold xenon 1200.1 to power it. But I will set the gain accordingly to give my sub exactly 1000rms. I can't wait. I am so excited to see how this sub performs WITH THE DESIRED RMS rating. OMFG I am excited. Plus this will be my first sub with a ported box and actually built to specs instead of pre fabb box. I am used to a sealed enclosure LOL.im hearing great things about this icon 12 sub. I am stoked... for picking the Icon.
