what is the difference between dual one or dual 2 ohm???
im looking to power up at btl 18 will 2 rockford 2500?
the difference between dual 1 and 2 are the different ohms you can wire it too.
am i getting this right you want to power 2 2500 Rockfords to one BTL...is that right?
I would recommend only using one 2500 for a BTL
you would need a dual 2 IF you are only using one amp
If I get dual 1 ohm can I hook up one amp to one terminal and the other one to the other terminal? thanks!
Yeah since the rockfords are 1 ohm stable stable then you need to get the dual 2 ohm subwoofer so you can wire it in parallel to 1 ohm.
