Posted November 28, 200916 yr I have a 1200d coming and I need just 1 12, which will be going under the back seat of my silverado crew cab. So depth is limited to 7" maxThats figuring in the MDF and leaving another .5" from bottom of driver to the board.Im hoping I can go ported but if not then itll be sealed. Do you guys recommend going with the ICON or the BL with all upgradesThe 1200d is supposed to do almost 1500w rms at 1ohm so Id like to take advantage of all that power
November 29, 200916 yr Admin If you are looking to push the amp to the limit, get the BL loaded. But if you want to set your gains to the drivers capabilities, the Icon will be fine. The Icon and BL are quite different drivers that are really designed to be in two different installs. Please take a peak at our new member topics and then come on back to give us some more info on your goals etc.
November 29, 200916 yr Author To help get the information you desire when wondering this type of question, please include the following information.a.Previous products that you have used (i.e. amplifiers if its an amplifier question, etc)RF Punch HX2 and eclipse 7200 series alumb.Budgetary constraintsunder $350 totalc.Vehicle which the equipment will be used in2007 silverado crew cab, underneath the seatd.Other products you have heard, but have not owned that you enjoyed & their install particuars.e.Musical preferencesmodern rock, some country, and some hip hopf.System goalsTo hit hard and feel the bass when the drums hit and roll, so I like to feel that HIT and feel the rumble real goodg.List any research you have previously donejust the amp I wanted and not really sure how else to figure out what sub would work best other than to ask a forum like I am now
