Posted December 6, 200916 yr I ordered a 50.4 in hopes of bridging it to get the proper power I need out of my midbasses. After purchasing the amplifier, I looked at the wiring diagram for bridging and it only shows mono subwoofer.I wanted to run these at stereo for my midbasses xover actively from 60-1.2kHz. Is bridging out of the question?
December 7, 200916 yr I ordered a 50.4 in hopes of bridging it to get the proper power I need out of my midbasses. After purchasing the amplifier, I looked at the wiring diagram for bridging and it only shows mono subwoofer.I wanted to run these at stereo for my midbasses xover actively from 60-1.2kHz. Is bridging out of the question?All the manual shows is impedance loads between 4 and 8 ohms in the bridged mode.So if you were looking to run them in two ohm bridged, I dont think it will work.
December 7, 200916 yr Author bridge the front 2 channels for the right and the back 2 for the left.Nawyce! Thanks!
December 7, 200916 yr Author I ordered a 50.4 in hopes of bridging it to get the proper power I need out of my midbasses. After purchasing the amplifier, I looked at the wiring diagram for bridging and it only shows mono subwoofer.I wanted to run these at stereo for my midbasses xover actively from 60-1.2kHz. Is bridging out of the question?All the manual shows is impedance loads between 4 and 8 ohms in the bridged mode.So if you were looking to run them in two ohm bridged, I dont think it will work.I am running 2 channels @ 4 ohm. Thank you though.
