Posted June 17, 200520 yr i traded my $500 gift certificate for these 2 db extreme soundstreams. they seem to be a little bit beefier than the RL-p's they are ran to a .5 ohm final load. my amp seems to be doing ok, w/ impedance rise i expect it to be around 1ohm. i'll graph it later to make sure. the basket is about 1/8-1/4" bigger on the dbx's. well here's the pics.....
June 17, 200520 yr Admin I would not be suprised if the SoundStreams are louder, but I know they are not going to sound better
June 17, 200520 yr Author I feel a competition a-brewin'! <{POST_SNAPBACK}>i'm workin on it :ph34r: i've got a few things already.given the same power...well a little more to the soundstreams, cause they're wired .5ohm vs the rl-p at 1ohm.pros:the soundstreams are louder.the little bit i've heard, the lows have more authority.cons: the basket is wider than the rl-p's. it took me a good 1/2 hour in my hot@ss car w/ a little dremel tool grinding away at my holes so they'd fit.the surrounds are so much taller that i can't listen to them w/ the seats up. the rl-p's i could have them fully excurting and not touch the seat. but the soundstreams touch the seat not moving and unfortunatly i've been moving stuff tonite and had to have the seat up
June 19, 200520 yr Author here is some quick porn. i'll get some better up later.....http://www.realmofexcursion.com/videos/Sou...dbextreme.1.wmv
June 19, 200520 yr Author here is the impedance graph between the rl-p and the dbx. you think my 1 ohm stable amp will be ok dipping to .75 on occasion?
June 19, 200520 yr Author and here is a quick spec comparisondb extreme--------------------RL-pmax 2500w----------------------1200w(?) rms 1000w-----------------------500wfs 38.2--------------------------27.487vas 2.305ft----------------------5.253ftqms 4.594-----------------------3.728qes .465-------------------------.508qts .422--------------------------.447xmax 14.35mm-----------------24.6spl 99.9--------------------------89.67 @1wattrec box ported3.3ft^3--------------------------2.5-3.5 ft^327.5in^2 port @ 45Hz----------35in^2 port @ 28HzsealedN/A-------------------------------1.5-2.5ft^3
June 19, 200520 yr Is that really 99 dB effecient ?14MM x max is weak !P.SThey look like Brahmas if you take off the dust cap and add another slug
June 19, 200520 yr Author Is that really 99 dB effecient ?14MM x max is weak !P.SThey look like Brahmas if you take off the dust cap and add another slug<{POST_SNAPBACK}>i'm not to big on the shiny dust cap. could i get a boob and glue it over that one? if so where would i get boobs? it wouldn't change anything would it?
June 19, 200520 yr you can take the cap off and put another on.I dont think it would change anything audibly
June 19, 200520 yr Author you can take the cap off and put another on.I dont think it would change anything audibly<{POST_SNAPBACK}>well i don't really wanna take that one off. (fear of breaking something) were would i get them?
June 19, 200520 yr I took my shiva one offI took my JBL one offDidnt crack/tear eitherJust run a knife around it where it contacts the wooferPartsexpress has some that you can buyIf you choose to get one from them contacg Steve, he has some deal on PE shipping
June 24, 200520 yr So why is the sub with 10mm less xmax louder? Can anyone explain, I just don't get it. I'm assuming that he has enough power to make the RL-P's move to their potential, so why are they not louder. (is the 1db in efficiency the reason?)
June 24, 200520 yr xmax isnt always necessarily louder - has much more to do with acoustical alignment etc.if you compete in spl for any amount of time you'll figure it out quickly
June 25, 200520 yr xmax isnt always necessarily louder - has much more to do with acoustical alignment etc.if you compete in spl for any amount of time you'll figure it out quickly <{POST_SNAPBACK}>yea, knew that *cough* stroker*cough*
