Posted December 24, 200915 yr As the title saysWhere can I get remote wire? Is it possible to get it without a car kit?I need to connect my new Sundown amp but I dont have any remote wire lol
December 24, 200915 yr Or you can use a speaker wire just peel off one wire if you wannaa be cheap lol
December 24, 200915 yr Any 16 gauge primary or speaker wire will work! Wire is wire for that application!
December 24, 200915 yr Or you can use a speaker wire just peel off one wire if you wannaa be cheap lolHey, thats me. Plain ole radio shack home stereo wire spliced in half. Doesnt cost me a dime.
December 24, 200915 yr My Knukonceptz RCA's have a remote wire built in them they're pretty cheap. i believe the lead wire is aprox 16-18 gauge wire, pretty small too
December 24, 200915 yr Go to your local Autozone and check out there 16-18ga speaker wire, you can get a good 30ft for less that 5 bucks
December 24, 200915 yr Author Ok cool, I didnt know you could use speaker wire too haha.Well, now I just need to find out if my current 4 gauge power/ground cables will fit in the 1/0 Sundown connectors. The screw seems pretty big...
December 24, 200915 yr Ok cool, I didnt know you could use speaker wire too haha.Well, now I just need to find out if my current 4 gauge power/ground cables will fit in the 1/0 Sundown connectors. The screw seems pretty big...It will, I currently have 4 gauge running into my saz 1500d, but it's only running at 2 ohm. I'll be putting in all 1/0 wire when I put in my xcon and drop to 1 ohm.
December 24, 200915 yr Ok cool, I didnt know you could use speaker wire too haha.Well, now I just need to find out if my current 4 gauge power/ground cables will fit in the 1/0 Sundown connectors. The screw seems pretty big...Yep the only use for that wire is to turn amps on/off. Why don't you use 1/0 for you Sundown?
December 24, 200915 yr Ok cool, I didnt know you could use speaker wire too haha.Well, now I just need to find out if my current 4 gauge power/ground cables will fit in the 1/0 Sundown connectors. The screw seems pretty big...Yep the only use for that wire is to turn amps on/off. Why don't you use 1/0 for you Sundown?He is only running it at 2 ohms.
December 24, 200915 yr Author Yep, its only for my temporary Pioneer which runs 1000watts RMS @ 2ohms.After Im done saving for my BTL, Alternator, Battery, things will go down to 1ohm My Pioneer doesnt need 1/0 cables yet, thats why Im sticking to what I have for now.
December 25, 200915 yr My Knukonceptz RCA's have a remote wire built in them they're pretty cheap. i believe the lead wire is aprox 16-18 gauge wire, pretty small tooSeriously, what model?I use Krystal RCA Kables, and didn't notice..
December 25, 200915 yr My Knukonceptz RCA's have a remote wire built in them they're pretty cheap. i believe the lead wire is aprox 16-18 gauge wire, pretty small tooSeriously, what model?I use Krystal RCA Kables, and didn't notice..I use the KnuKonceptz Klarity kables, the blue ones and they have the remote wire in between them.
