is the audioque 2200d a good match with the 15 inch fibtl?has anybody used or heard this amp?
They are good amps, put out rated power and then some. If it is within your budget then it will be a good match for you and your BTL.
thanks jaycee do you know if the hdc3 audioques subs are good?man the price for that amp is only little over $300..
I havent experimented with the HDC3's but I heard good things about them, there are some reviews floating around this site about them (I heard they get loud).
x2, I have heard positive results from Audioque's equipment
There was a thread in the Fi section about a guys new 15" BL. His amp took a poo though, and although it was not this amp, someone thought it was, and had negative things to say about the amp, but I have heard nothing bad about the subs. Perhaps the problem with the amp was a rare occurrence, so check the thread out:
da link
At one time i ordered 2 of these amps when they were only a couple months into production and one came in defective from shipping damage unknown to me and fried both amps on the spot when strapped.
Covered under warranty and after weeks of diagnosing until the problem was finally found, they have been working ever since. I eventually sold them both and have never had complaints and been in use for over 2yrs now.
