Posted January 5, 201015 yr Alrite So I bought a Fi BL 18" sub and I wanted to kno something. What if I buy a Fi BTL 18" sub as well. Can I use both of those subs in the same box or I can't ?Thanks!
January 5, 201015 yr Alrite So I bought a Fi BL 18" sub and I wanted to kno something. What if I buy a Fi BTL 18" sub as well. Can I use both of those subs in the same box or I can't ?Thanks!no, the btl is capable of more power
January 5, 201015 yr Alrite So I bought a Fi BL 18" sub and I wanted to kno something. What if I buy a Fi BTL 18" sub as well. Can I use both of those subs in the same box or I can't ?Thanks!no, the btl is capable of more powerx2, absolutely NO
January 5, 201015 yr They are two different drivers. The BTL's suspension is stiffer than the BL by 17.9 l, that means the BL's suspension will move a lot more and make it prone to mechanical failure if put in a common chamber enclosure. If they are separate you won't have a problem, but it's possible they have a diffferent "sound".
January 5, 201015 yr Alrite So I bought a Fi BL 18" sub and I wanted to kno something. What if I buy a Fi BTL 18" sub as well. Can I use both of those subs in the same box or I can't ?Thanks!Why would you want to do this, buy two of the same subs
