Posted January 11, 201016 yr I have a 09 charger my stock speakers in the front are 6x9 and my rear deck also has 6x9 ,i want to change each of them to the kicker 6.5" component sets could i run these off the saz 50.4?They say there 75 watts rms...
January 11, 201016 yr I believe Jacob had made a statement in another thread questioning ouput for the 50.4. He had said that it would provide enough power for 90% or 95% of the components on the market.....hope that helps Edited January 11, 201016 yr by chicagofan
January 11, 201016 yr I believe Jacob had made a statement in another thread questioning ouput for the 50.4. He had said that it would provide enough power for 90% or 95% of the components on the market.....hope that helps x2, you wont have any problems and if you just want to have head room then go for the SAX-100.4 if you feel the SAX-50.4 isnt good enough for you.
January 11, 201016 yr Buy the SAX-50.4 it is a great little amplifier and will provide more than enough output for your speakers.
January 11, 201016 yr Buy the SAX-50.4 it is a great little amplifier and will provide more than enough output for your speakers.x10
January 11, 201016 yr Buy the SAX-50.4 it is a great little amplifier and will provide more than enough output for your speakers.x10the 50.4 will be perfect. i just got done taking my old system out of my charger since i got a new toy car. just a tip for you if you have a sunroof and ur putting a sub in the charger you will need to go to the dealership and have them replace the clip that holds the headliner up towards the sunroof it rattles like hell. its a free charge its a known issue with the chargers. good luck man
January 14, 201016 yr should be plenty of power.. im going to use a 50.4 bridged to power ID ctx65cs comps
January 14, 201016 yr This amp is really powerful when it's bridged. My Focal comp set seems to love it ! I hope they will last with so much on them (2 x 160 watts rms IIRC).The Sundown boss told us it gives about 4 x 60 watts, so enough for your speakers.
