Posted January 13, 201015 yr the tweeter in my sig, if i change the tweeter to a different one while using the crossover would it matter? or because it is still getting the same crossover slopes its ok? Edited January 13, 201015 yr by jfin1204
January 13, 201015 yr the tweeter in my sig, if i change the tweeter to a different one while using the crossover would it matter? or because it is still getting the same crossover slopes its ok?Clarify please?
January 13, 201015 yr kind of a vague question....when you ask "would it matter" in what way are you meaning?
January 13, 201015 yr I see no tweeter in your sig, in fact I seen no sig. A lot of people have sigs turned off.
January 13, 201015 yr I see no tweeter in your sig, in fact I seen no sig. A lot of people have sigs turned off.He is referring to " 1" tweet carbon kevlar cones"
January 13, 201015 yr Author sorry the tweeter in the alphasonik pct 6551 that i have, i dont like the way i have to mount in my doors. so i havent put it in yet. i would like to change to another tweeter. would it matter what tweeter i use? Edited January 13, 201015 yr by jfin1204
January 13, 201015 yr sorry the tweeter in the alphasonik pct 6551 that i have, i dont like the way i have to mount in my doors. so i havent put it in yet. i would like to change to another tweeter. would it matter what tweeter i use?Yes it would matter unless the you can find tweeters with the same specs as they one you have now, if that was the case there wouldnt be thousands of crossovers out there if one worked on all the tweeters in the market.
January 13, 201015 yr Those are just basic small format tweeters, I'm not sure what kind of tweeter you want that will fit any differently or better.
January 13, 201015 yr Author i dont like the chrome A. seems little but that will be the only chrome piece in the car and i dont want it to stand out. guess i could paint it black or take off. Edited January 13, 201015 yr by jfin1204
January 13, 201015 yr i dont like the chrome A. seems little but that will be the only chrome piece in the car and i dont want it to stand out. guess i could paint it black or take off.That would be the cheapest and smartest thing to do instead of replacing a tweeter just because of its looks that can be altered.
January 14, 201015 yr It could make a HUGE difference. If you don't truly understand exactly what you have and the results of changing it, I would highly recommend you don't.
January 14, 201015 yr Author these three ways sound great would not like to change the sound, only appearance of it.
January 15, 201015 yr Changing the driver out is NOT the way to do that. Paint it, color it, customize it but don't change it.
