January 15, 201015 yr SAZ 1000d!! or a used saz2000!what kind a system you wnat to run? goal? car? sub? any mroe info would be awesome!
January 15, 201015 yr SAZ 1000d!! or a used saz2000!what kind a system you wnat to run? goal? car? sub? any mroe info would be awesome!X2. everything he said plus what kind of electrical upgrads you have
January 15, 201015 yr hey guys i hav $300 to buy an amp what can i get i need a deal For what? Information is your friend to get accurate answers, who can give you an amp recommendation if we dont even know what it will be powering?
January 15, 201015 yr Author well the saz 2000 will be good if i can find a deal . i hav a jeep that had in 2 type r with a saz1200d which some guy like it more than me so i sell the system an know will like to star over so i need to find some deal
January 15, 201015 yr o so you are starting fresh!! nice!! and the saz2000 is actualy 380~SAZ-2000D Refurbished [sAZ-2000D] - $382.50 : dB-r Electronics, Online Storethere you go! also i think he has some 1200d listed on there also for under 200~ and a saz1000d for under 200$ also!
January 15, 201015 yr Author ya am startin all over on that site it say saz 2000d not availiableand yes i would get amp 1st an then go from their cause i think the amp is the most inportant right an it can be use once if it good Edited January 15, 201015 yr by mr.tigger
January 16, 201015 yr The amplifier is not the most important aspect. Select the amplifier last. Make a subwoofer selection first, then chose an amp to match the subwoofers you've selected. Purchasing an amplifier first will limit the subwoofers you can chose......this is not a smart way to go about things. You're doing things ass-backwards.
January 16, 201015 yr i think the first thing i would do i had to do it all over again would be:1. car electrical ---big 3 in either 1/0 or 4/02. set my goal (daily or comp)3. look for a sub which met goal number 24. get an amp to match goal 3, if not doulbe the power for future application5. pick a battery (or batteries) to suit everything6. sub box design7. get advice!something along those lines! also find out how mcuh space you have to work with. like if i have a 7cubic truck you can fit like 2-15's inchs for example or if i own a hatchback or watever!
January 16, 201015 yr Author i think the first thing i would do i had to do it all over again would be:1. car electrical ---big 3 in either 1/0 or 4/02. set my goal (daily or comp)3. look for a sub which met goal number 24. get an amp to match goal 3, if not doulbe the power for future application5. pick a battery (or batteries) to suit everything6. sub box design7. get advice!something along those lines! also find out how mcuh space you have to work with. like if i have a 7cubic truck you can fit like 2-15's inchs for example or if i own a hatchback or watever!Thanks to all you guys there who is teachin me so much am new to car audio. so plz give me a break if dont no wat am sayin i hav already did the big 3 with 1/0 wire with stock alt an 2 yellow top batt one in the front an one in the back . my goal is for daily playin mostly reggae an hip hop . as for sub am leanin to 2 12" in a box size about 36x20x16 tune to ???hz
January 16, 201015 yr there is a good start!2-yellow topsbig 3and a ~5.355 cubic box~ nice plenty of volume! now tuning! try 35hz's and go from there!you want to go with 2-12inch subs! i would say go with sundown z15's!! and then get 1-saz2000 lol! lol but wiat for some other ppl to chime in who MIGHT recommend the xcon or icon subs for your type of music!
January 16, 201015 yr Author there is a good start!2-yellow topsbig 3and a ~5.355 cubic box~ nice plenty of volume! now tuning! try 35hz's and go from there!you want to go with 2-12inch subs! i would say go with sundown z15's!! and then get 1-saz2000 lol! lol but wiat for some other ppl to chime in who MIGHT recommend the xcon or icon subs for your type of music!so wat u sayin 2 sundown z15 wow
January 16, 201015 yr there is a good start!2-yellow topsbig 3and a ~5.355 cubic box~ nice plenty of volume! now tuning! try 35hz's and go from there!you want to go with 2-12inch subs! i would say go with sundown z15's!! and then get 1-saz2000 lol! lol but wiat for some other ppl to chime in who MIGHT recommend the xcon or icon subs for your type of music!so wat u sayin 2 sundown z15 wowand by z15's i mean sa12's lol!!! but i am just a sundown head! for some reason you siad duel 12's and i jsut though about 15inch subs lol! sorry my bad!
January 16, 201015 yr What is your budget on subs? What is your budget on electrical upgrades? Are you gonna build your own box or get one built for you?
January 16, 201015 yr What is your budget on subs? What is your budget on electrical upgrades? Are you gonna build your own box or get one built for you?x2 budget will determine everything!! good call!! Edited January 16, 201015 yr by CrazyKenKid
January 16, 201015 yr Author What is your budget on subs? What is your budget on electrical upgrades? Are you gonna build your own box or get one built for you?well i was thinkin about $400 for sub. builtin my own box and on electrical upgreades wat else do i need? Edited January 16, 201015 yr by mr.tigger
January 16, 201015 yr A nice setup for you would be 2 - Sundown Audio SA-12"s or 2 - Inciminator Audio Lethal Injection 12"s and a SAE-1200v2. You will need to do the Big 3 wiring upgrades and get a nice size secondary battery depending on how big your stock alternator is and if you will have any other amps in your setup. The subs are $200 each and amp is around $300.
January 16, 201015 yr Author A nice setup for you would be 2 - Sundown Audio SA-12"s or 2 - Inciminator Audio Lethal Injection 12"s and a SAE-1200v2. You will need to do the Big 3 wiring upgrades and get a nice size secondary battery depending on how big your stock alternator is and if you will have any other amps in your setup. The subs are $200 each and amp is around $300.wont the sae-1200v2 be Availible till nov?
January 16, 201015 yr Naw that is when the presale was supposed to be over with last year, Jacob just got done shipping out the pre-sold ordered ones.
