Hello I was wanting to use the 100.4 for my front stage. I was going to run 6.5 in the kicks and maybe a 3 or 4 inch in my front pillars. I was wondering can you bandpass, for example channel's 3&4 with the subsonic filter set at 150 hz then setting the Low pass frequency crossover at 4,500Hz for the 6.5. Then channels 1&2 would be set on High Pass and the High Pass Crossover set at 750Hz for my pillars.
I will also be running tweeters I will be running those on channels 1&2 also. How could I Passively crossover these. I was thinking around around 7,000-8,000Hz any info would be helpful. Thanks
The subsonic can be used to band-pass.
ok cool
Edited by alexj01_83
